What Sata 6 controller for P67?
Discussion in 'Intel MoBos' started by zod96, Jan 6, 2011.
  1. zod96
    zod96 Suspected BAD TRADER
    2,709
    Feb 23, 2008
    I want to make sure I get a P67 motherboard that has a Intel Sata 6 controller and not a marvel or highpoint one. Dose anyone know if the asus or msi boards have the intel controller?
  2. loki7
    loki7 Limp Gawd
    239
    Jul 16, 2008
    I assume all boards have at least 2 Intel SATA 3.0 ports, considering it's the P67 Intel chipset.
    Edit:
    What strikes me is which boards have Intel Gigabit controllers. I haven't seen all P67 boards, but have only noticed upper-end ASUS boards with Intel Gigabit and of course Intel's own. Disappointed the UD7 doesn't. Any $200+ board should. Any $300+ really should. :p
  3. zod96
    2,709
    Feb 23, 2008
    yes I know that. I'm talking about the sata 6 controller
  4. loki7
    loki7 Limp Gawd
    239
    Jul 16, 2008
    Did I not answer the question? I'm confused. :D
  5. todlerix
    todlerix 2[H]4U
    2,244
    Apr 25, 2003
    sata3 = sata6.0Gbps
  6. Hostile
    Hostile Gawd
    687
    Feb 24, 2004
    lol you sure?
  7. E4g1e
    E4g1e [H]ardness Supreme
    7,055
    May 21, 2002
    The Asus P67 motherboards (the P8P67 series) all have at least three internal SATA 6 Gbps ports - two of which are native to the Intel P67 PCH, the other two (P8P67, P8P67 PRO, P8P67 EVO, P8P67 Deluxe) or one (P8P67 LE) using a Marvell controller. What would have been a second Marvell-controlled SATA 6 Gbps port on the P8P67 LE is instead used by an eSATA port.
  8. zod96
    2,709
    Feb 23, 2008
    Ops :) My bad I didn't even notice that. I always just thought it was called sata 6 :) you learn something new every day...
  9. Pretzel
    Pretzel Limp Gawd
    266
    Aug 16, 2006
    Here's the Asus P67 P8P67 boards, as you can see below you'd want to use the (gray) ports for 6.0 Gb/s through the intel chipset.. instead of the the slower Marvell which are (navy blue)
    Intel® P67 Express Chipset
    2 xSATA 6.0 Gb/s ports (gray)
    4 xSATA 3.0 Gb/s ports (blue)
    Intel® Rapid Storage Technology Support RAID 0,1,5,10
    Marvell® PCIe 9128 SATA 6Gb/s controller with HyperDuo function*
    2 xSATA 6.0 Gb/s ports (navy blue)
    The MSI also has 4 x Sata 3 (6.0 Gbs) I assume 2 are intel and 2 are marvell like the Asus.
  10. Hostile
    Hostile Gawd
    687
    Feb 24, 2004
    They're white actually. :p
  11. Pretzel
    Pretzel Limp Gawd
    266
    Aug 16, 2006
    In all the benches the Intel chipset is far superior to the Marvell.. makes you wonder why they even included the Marvell and instead went with 4 x Intel 6 GBs sata. :confused:
  12. JamesL
    JamesL Gawd
    657
    Nov 7, 2007
    afaik, Intel sata 6.0Gbps controllers were integrated into the p67 chipset.
    If the p67 chipset only supports 2 ports, than you need to find other means of providing additional sata6Gbps ports which is where the Marvell controller comes in.
  13. Finny76
    Finny76 [H]ard|Gawd
    1,167
    Aug 31, 2002
    +1
    What about the PCIex16 lanes?
  14. JamesL
    JamesL Gawd
    657
    Nov 7, 2007
    what about them?
    I think the controller and bandwidth enough for a single pcie-x16 lane is integrated into the CPU and not the chipset..
    Single pcie-x16 slot is simplest/cheapest to implement for budget motherboards, while other motherboards may find ways to split the bandwidth (x8/x8 or some other configuration), implement sli/xfire(they also probably have to pay for SLI licensing), or find another workaround; ie. nf200
    everything above is "AFAIK".. and/or speculation though...
