Cov
- Dec 3, 2007
Hi,
my upcoming computer is going to have the following hardware:
CPU _ Intel i5 2500K
Mainboard _ Intel DH67CF
RAM _ ???
The system should be power sufficient, reliable and silent.
If I could, I would underclock & undervolt, but afaik the mainboard does not allow that.
It has two banks which can take up to 16 GB of RAM modules.
My question: can you recommend compatible RAM modules for that system, please ?
The chipset is called H67, suitable for DDR3 1333/1066-MHz RAM.
Would it work if I took one single 8GB module only instead of 2x4 GB, or do both banks have to be filled ?
If a single module was enough, could you recommend any suitable 8GB module ?
Otherwise I would go for either 2x4 or 2x8 GB. Here are some examples:
1. F3-10666CL9D-8GBXL (4GB2x)
2. F3-10666CL9D-8GBRL (4GBx2)
3. F3-10666CL9S-4GBRL (4GBx1)
4. F3-10600CL9D-8GBNT (4GBx2)
I wouldn't mind taking RAMs with higher specs than the motherboard is capable to make use of. They all are downwards compatible anyway, right ?
Some of them have 1.35 instead of 1.5 V .. would that make any difference in power consumption and/or heat generation ?
Thank you
RAM _ ???
Thank you
