Corsair ? What Series
Mushkin?
PC 3200? 3500? 4000?
DDR500 sticks at 2,2,2,
3,3,3,10 1T sticks?
my CPU:
Model: AMD Athlon 64
Core: ClawHammer
Operating Frequency: 2.0GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/1024K
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 754
No idea what the FSB is cause it says Integrated into Chip. Anyone know what that means?
I am also getting the Nvidia 6800 GT later
I really dont want to spend more then $300 on ram but if its going to help the speed a lot then i will speed up to $400
#1 OCZ Enhanced Latency Series Platinum Edition (512MBx2) DDR PC-3200
Cas Latency: 2-3-2-5 1T $248.00
#2 OCZ Enhanced Bandwidth Series Platinum Edition (512MBx2) DDR PC-3500
Cas Latency: 2.5-3-2-8 $299.00
#3 CORSAIR XMS Xtreme Memory Speed Series, Xtra-Low Latency Platinum (512MBx2) DDR PC-3200
Cas Latency: 2-2-2-5 $298.00
#4 Mushkin 184 Pin 1GB(512MBx2) DDR PC-3200 Level One
Cas Latency: 2-3-2 $243.00
Whats the best bang for my buck? with those specs? i dont want my Ram to be my bottle neck
Posted this in the memory fourm but didnt get anything
Mushkin?
3,3,3,10 1T sticks?
my CPU:
Core: ClawHammer
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 754
