So, when Windows XP is cutoff and if activation is no longer possible,
Pirates to the rescue. You can run XP without any activation crap since forever.
The first thing to do in that situation is right click and update driver, search online, and there's a good chance one or more of those devices has a reference driver available from MS.
After all that, it's possible that there may not be one or more device drivers available. In that case, a replacement card (PCI or PCIe or USB) for that device would need to be used if that functionality is essential..
if there is a driver from mircosoft, shouldn't win 7 automatically find that driver in the 1st place? As to your 2nd pt., that's exactly what needed to be done. In 1 case, some1 upgraded to win 7, there is no driver for ethernet, so I have to buy a PCI card to insert in the PC because there is no driver.
And the pt. is, the time spent on digging out that many drivers, costs more than the PCI card itself.
But what is a bigger concern, is not the video or audio, or ethernet driver, rather, the windows core drivers.
Say you just bought a brand new motherboard, and it does c/w win 7 drivers. So you installed a fresh win 7 OS on the PC. And the next thing you should do, is to install all those drivers from the manufacturers CD.
If you don't, you'll see a list of yellow ! on those core drivers, such as USB 3.0 drivers, storage controller drivers, and those are hard to find by searching on the internet. And needless to say, even if you miss 1, you can't get win 7 to work properly.
That's a good suggestion, but no, you have to click the search online button instead of browsing in the update driver dialog. Windows installer finds the included drivers on disc, but does not automatically search online for any missing drivers. Same behavior since Win9x, so it's nothing new.if there is a driver from mircosoft, shouldn't win 7 automatically find that driver in the 1st place?
Looking at this from a non-security viewpoint, my issue is with compatibility with some software.
And, it varies from person to person, computer to computer, software to software.
I'll give you a good example.
A friend plays Final Fantasy XI. The graphics engine is both CPU-bound (relies little on the GPU) and is DirectX 8.1-based. He gets the same issues with both Windows 7 and Windows 8 (both 64-bit) with his Radeon HD 6870. These issues are massive texture flickering on all player characters, NPCs, and monsters. This computer has a GIgabyte board and i7 920.
He upgraded his computer to brand new parts-- CPU, GPU, board, PSU, memory-- which are an i7-4670K and a different board manufacturer, ASUS. His video card this time was a Radeon HD 7950.
Guess what? Same graphical issues with both Windows 7 and Windows 8. Catalyst drivers 12.10 to 13.6 Beta were tested as well. Nothing fixed it whether using Windower, turning off certain effects, turning on Graphics stabilization in the configuration. Nothing. Leaving no anti-virus installed, updating to latest drivers, running as Admin on the program. Absolutely nothing fixed it.
He's resorted to installing Windows XP SP3 on a separate partition just to play this game. And, guess what? The graphical issues disappeared.
Now, I play FFXI as well with a Radeon HD 6950 but Windows 8 Pro 64-bit and an ASRock board with Catalyst 12.10 installed. NO graphical issues whatsoever.
So, it really varies from person to person.
Another issue I've come across is with one of the games I play quite often-- Pangya. Now this could be a problem with the developer that's put into the game. But, the game has issues with Windows 7 and Windows 8. Yes, both Windows 7 and 8 can run the game, but it makes the taskbar funky (flickers), Start button disappears (in Windows 7), Skype crashes while the game is running, Steam crashes, and very rarely other programs throws off a random out of memory error on a system with 16GB of RAM installed.
I put the game in Windows XP Pro SP3 installed in a VM and run it through VMWare Workstation. Guess what? No issues whatsover. That game runs absolutely fine as if it's running on another computer and native hardware.
So, when Windows XP is cutoff and if activation is no longer possible, it's going to be a problem to a lot of people who run certain games. Why? These developers refuse to update their games or reprogram them to have better compatibility with newer Windows operating systems.
It's going to be a problem later on when the DirectX versions are revised in each iteration and support for older DirectX versions are either emulated or certain features are deprecated or removed. These games are going to have compatibility issues regardless because of stubborn developers like Square-Enix and a few others. That is something the end-user cannot fix except resorting to older operating system such as Windows XP.
There is no way a 10 yr. old PC capable running win 7, as the motherboard manufacturer couldn't possibly have the drivers for its network card, audio, etc.
People will produce unofficial updates and tweaked drivers for XP just like they have for 2000. I run Firefox 22.0 in Win2k as well as the latest Flash and Java. My guess, XP will be around for a long time.
The drawback of using XP after EOL will be the same as the drawbacks of using it right now...You're using an archaic, slow, insecure, poorly supported, less stable, less functional operating system that everybody else wishes would have gone away years ago. If you're okay with that (and I don't know why you ever would be), the end of support is probably meaningless to you anyways.
Old and insecure yes, slow compared to win7? That's hard to swallow.
Using unofficial updates only creates more security problems than they could ever solve. The creators wouldn't have access to the source code to see how MS wrote the bugged code, nor would they have the tools or dedicated manpower to find, code, test, and validate the fix. They also would have a hard time knowing if anything they changed caused any problems in other code. You're just asking for problems.
