What mouse and keyboard do you use?
CastletonSnob
I was just curious as to what mouse and keyboard you use. I use a Dell wired mouse and a Microsoft 600 keyboard.
Archaea
Corsair K70 Keyboard - Fantastic, best keyboard I've ever used.
Logitech G603 mouse - fair to middling (scroll wheel has random issues (scroll down, scrolls up type nonsense sometimes), otherwise I would rate it higher, tracking is good, wireless speed is imperceptible over wired, battery life is stupid long)
Westwood
G910 Keyboard
G502 Mouse
The last Logitech equipment I'll ever buy. Their G-Hub software is hot garbage and I'm sick of it.
Zeoclang
Microsoft Internet Keyboard - According to the date code it just made 20 years old
Gigabyte M6800 Mouse - Good inexpensive mouse but the thumb rest pad slowly slides off
The keyboard is just a cheap wireless Logitech K270. My mouse is a Logitech G305, which I really, really like.
criccio
Fully Equipped
Home
Logitech G Pro Keyboard
Logitech G703 Mouse
Work
Corsair K65 Lux Keyboard
Logitech MX Master 3 Mouse
atarione
The mouse and keyboard are very important to how the PC usage experience is... as such I think spending $ on these items makes sense.
My set up.. Filco MT2 TKL mx-red (dampers/ vortex pbt double-shot keycaps) and a Steelseries Sensei 310 mouse. I have been running this combo for a good while now.. very pleased with it.. filco_310.jpg
Deadjasper
My set up.. Filco MT2 TKL mx-red (dampers/ vortex pbt double-shot keycaps) and a Steelseries Sensei 310 mouse. I have been running this combo for a good while now.. very pleased with it.. View attachment 368996
Nice Vintage receiver. What is it?
Wiz33
Logitech G915 & G502, G915 work fine but I have since changed to a G915 TKLto give more room for the mouse on the tray but G502 kinda have transmission problem at 8ft from time to time. Going to have to use a longer USB extension cable to bring the receiver closer or have to look for an alternative. Just ordered the Asus Chakram, will see if it does any better.
crawfish
Logitech K750 keyboard with solar panels covered by electrical tape so I can use a normal CR2032
Logitech M705 Marathon Mouse
Been using them for years, and I like them so much I bought several spares of each.
Hallyday
I got a RF87U, though a NiZ Plum will replace it soon (it's in shipment). This one has seen a fair amount of usage, and the NiZ is a bit more modern / all 35g anyway.
For mouse, I have a Pwnage Ultra Custom Ergo, which turned out to be better than I thought. Wireless lasts quite a bit, no wire to deal around when moving mouse - pretty lightweight too.
Zepher
[H]ipster Replacement
how long does the CR2032 last? I ended up buying a replacement capacitor battery for one of the K750's I have. I think it was $10.
crawfish
A long time. I might replace it once a year, and the keyboard's in heavy use. I had to do something, because the solar panel recharging system never worked reliably for me. I even tried putting it in a window sill for hours on end, and it still wouldn't charge worth a damn.
revenant
Corsair K70 rgb mk.2 low profile (cherry mx speed switches) and a Glaive rgb pro.
Mizzer
My Logitech G500s is getting long in the tooth but man it’s a great mouse. I recently purchased the Logitech G502 Proteus Spectrum. I expect to be disappointed but we’ll see…
