What Mouse and Keyboard Are You Using Right Now?
Discussion in 'Mice and Keyboards' started by SamirD, Feb 13, 2018.
  1. N4CR
    N4CR 2[H]4U
    3,519
    Oct 17, 2011
    Kensington Expert Wired Trackball.
    Once you go track, you never go back.
  2. TXE36
    TXE36 n00b
    19
    Jun 14, 2018
    Old school. Vintage IBM model M and CH Trackball Pro, both modified for USB. I've tried the newer clicky keyboards but they just don't compare with the classic. I like optical track balls for the lower hassle, but the ball bearings and pool ball in the CH make me keep coming back to it despite having to clean it more often. Both units are built like tanks.
    Since going to a track ball, a long time ago, I've never gone back to a rodent other than a few flirtations that resulted in the purchase of a [H] Ratpadz.
    -Mike
    N4CR likes this.
  3. N4CR
    N4CR 2[H]4U
    3,519
    Oct 17, 2011
    I have a slightly later IBM laying around that's intermittent (and was heavily gamed on), a model or two after the M and even though it's silicon membranes, it's super solid and still to this day my favorite silicon based keyboard. . I would gladly fight someone with that keyboard, it has 1-2mm steel backing for the keys, they don't build em like that much anymore.
    Love your choice of trackball, always wanted to try the CH Trackball pro, even better would be on the original bus setup on an old rig. But for modern use that USB mod is great, they are probably my favorite looking trackballs of all :D
    Same with the CST L-Track, uses same size ball as yours too, free spinning scroll is what I miss the most after an MX Master prior and that has it, plus external button support which would be best way around the issues with locked axis/slow mouse movement trigger incompatibility in the Kensington software.
  4. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    27,667
    Oct 29, 2000
    I agree. I like buckling spring the best too. I decided to try something newer this time around, but I kind for regret it.
  5. TXE36
    TXE36 n00b
    19
    Jun 14, 2018
    An intermittent model M is a symptom of a loose backplate. Newer IBM model Ms used heat swaged plastic pins to attache the back plate. Over time these can crack. The fix is to do the "bolt mod": https://wiki.geekhack.org/index.php?title=Modifications:IBM_Model_M:Nut_and_Bolt_Mod
    Mine is going to need this someday as every once in a while I have to thump it on the desk to get back a group of keys that go dead.
    LOL on the "fight someone", I almost commented you could use it as a weapon - it would make an effective bat.
    X-Mouse Button Control may be your friend here. It can program all four buttons of the CH including decent scroll with the ball. It may work with yours as well and it's free. I hadn't seen the CST L-Track - looks interesting.
    The other cool thing about the CH is you can easily replace the ball. The dirt cheap ($4) Mizerak cue ball is very heavy and has a relatively soft surface. After a bit of break in, it glides really well and the weight is really good for CAD/drawing/PCB layout work. I've also got a higher quality black cue ball from a billiard store ($10) that weighs a bit less and for gaming, a snooker ball which is very light. The ball that came with it was good quality too. It's nice to be able to customize it so cheap.
    There is a CH DT225 sometimes branded "Hologic" that is a native USB that gets rid of the hassle of getting a Trackball Pro serial to work on USB. One word of warning, the Trackball Pro serial is very picky about serial to USB adapters as the serial port voltage for most of these things is way lower than a real RS-232 port. I wound up making my own serial to USB adapter out of a Pro Micro hobbyist board and changing some resistors in the Trackball Pro. The DT225 is hassle free, but more expensive, about $80 used on Ebay. Trackball Pros can be had cheap if one has patience, I think I scored a NIB old stock one for $25. The bearings on the CH Trackballs are cheap and easy to replace and a good fix for one that feels gritty even when clean or if it skips.
    -Mike
    N4CR likes this.
  6. AG1M
    AG1M n00b
    63
    Apr 7, 2017
    Keyboard: Ducky Miya Pro Panda Edition @ MX Black Switches + QMX clips
    Mouse: Nixeus Revel @ Paracord cable
    Pad: SteelSeries DeX
    Lateralus, revenant and Mopower like this.
  7. Geforcepat
    Geforcepat Gawd
    888
    Jun 2, 2012
    Logitech G410 and logitech G303
    Gonna try to get a new mouse this spring/summer. wish we could get a g9 revial.
  8. FrEaKy
    FrEaKy [H] Movie and TV Show Review Guy
    13,377
    Jan 31, 2003
    Keyboard is a Drevo Blademaster Pro with Cherry MX Silver switches, keycaps are HyperX PBT Pudding Caps. Plan on picking up a couple accent keys later to complete.
    Mouse not shown is Logitech MX Ergo trackball mouse to finish off the work setup.
    N4CR, Commander Shepard and Lateralus like this.
  9. Commander Shepard
    Commander Shepard 2[H]4U
    3,505
    Apr 12, 2016
    My newest keyboard is the heaviest and best built beast I've ever tried. KBDFans75 with MX Silver switches and RGB light strip around the base. I added a set of PBT doubleshot key caps, but probably will swap them for a different color scheme.
    EDIT: I listed it in the For Sale thread. It requires some pesky programming to modify key mapping/functions. I ain't in the mood for all that.
  10. Zarathustra[H]
    27,667
    Oct 29, 2000
    I can't help but wonder, what's the point of backlighting if the keycaps don't have translucent lettering?
  11. Commander Shepard
    3,505
    Apr 12, 2016
    The keys are not backlit, only the strip around the base. The light you see is just reflected from inside the base.
  12. Domingo
    Domingo Skip My Posts
    16,861
    Jul 30, 2004
    More than a year later I'm still waiting for a new G700S or some type of successor.
  13. Dan_D
    Dan_D [H]ardOCP Motherboard Editor
    53,244
    Feb 9, 2002
    Well, the other day my Glorious PC Gaming Race keyboard started screwing up. The thing quit registering a couple of the keys so I went back to my Ducky Shine Zero. I may take the PC Gaming Race keyboard apart and see what I can do with it, but the Ducky will do for now.
    schizrade likes this.
  14. schizrade
    schizrade [H]ardness Supreme
    4,670
    Feb 15, 2003
    RIP PCMRKYBD.
    My Vortex Vibe is probably the best kybd I have ever used.
