Zarathustra[H]
Extremely [H]
- Oct 29, 2000
I'm still on this one, I tried replacing it but in the end I gave up on the new one because all the new ones have a USB connector and their own programs and drivers that drastically slow down my CPU and booting, especially the Roccat.
Really? I've never had a USB keyboard that required any kind of software or drivers to be installed, and I have had many.
I mean, sure,there is often optional software that can be installed to configure such things as RGB LED output, and the function of specialty keys (if you have those) but I have never encountered a USB keyboard that wouldn't just work if plugged in. And most have hotkeys on them you can use to do some basic lighting adjustments without any drivers.
Usually they just work with the standard USB Human Interface Device driver in their respective operating system. And that should slow down any PC made in the last, well, ever? As soon as PC's started shipping with USB ports, USB keyboards and Mice became standard and didn't really use any more resources than the PS2 devices that came before them.
I used PS/2 IBM Model M keyboards for longer than most, but have been on USB keyboards that work wirthout special drivers since ~2012 now.
This was the case for:
- Two Unicomp Model M keyboards I bought new in 2012. (these probably just used a USB to PS2 signaling adapter inside the keyboard case, but still.)
- Compact wireless Logtech K400 Trackpad & Keyboard I use for my HTPC.
- OG Ducky One backlit black keyboard with green switches I bought in 2018. (It had some optional software. I installed it once to test, but it was totally unnecessary.)
- Second OG Ducky One backlit black keyboard with clear switches I bought for work later in 2018. (Same as the above OG Ducky One)
- Ducky Shine 6 I bought for the kiddo in 2018. (It had optional software, but all it was really used for was custom per key RGB color settings. You could do most things, including change color presets and effects using hotkeys)
- Ducky One 2 I bought for my better half in 2019. (Same as OG Ducky, It had some optional software. I installed it once to test, but it was totally unnecessary)
- WASD Keyboards Code V3 I currently use. I don't even know if they offer an optional software suite for this one. I've never even checked.
- Various OEM wired USB keyboards from Dell, HP and others I have used in a pinch
I'm sure "super duper gaming boards" from the likes of Corsair, Razer, Steelseries, etc. etc. etc. all want you to install their software to get extra "features", probably in large part because they want to collect data and spy on you like everything else these days, but I'd also be shocked if they didn't just work out of the box with Microsofts (or Linux) USB HID Device driver.
I am curious. what motherboard do you even use that still has PS2 connectors? I haven't seen those in ages. I think the last motherboard I had with those was my Asus P9x79 WS Workstation board from 2011.
Don't get me wrong. I'm not suggesting there is anything wrong with your keyboard. It's probably great. And I'm also one of those people who - when I find something I like - I just kind of stick with it. But being averse to USB keyboards seems - well - a little bit odd in 2025. Heck, it would probably also have seen a little bit odd in 2015. And in 2010. USB has just kind of been the standard for so long now that your post is almost confusing to me
By all means, if you like your current keyboard you should continue to use it. Just don't be afraid of USB keyboards. They are literally not a problem.
Does anyone know why in some pictures and reviews the SteelSeries 7G has a small shift and in some it has a large shift? It's like there are several versions of this keyboard?
I am by no means an expert on Steelseries keyboards (I have never had one) but an educated guess would be that their ISO keyboard layouts (most common in European countries/languages) have the larger enter key and smaller left shift key like yours, and their ANSI layouts (most commonly used layout in the U.S.) have the larger left shift key, and a one row smaller enter key.
I don't know where you are located, but your keyboard appears to be a UK version, based on the fact that it is ISO layout and that it has a little pound symbol above the 3. Most English language keyboards made for the U.S. market will have the ANSI layout with the small enter key, and larger left shift, whereas most English language keyboards made for the UK market will have the ISO layout with the larger enter key, and smaller left shift.
I'd imagine that if you order in your market you will get the one that corresponds to the layout intended for your country. As to why you are seeing different layouts in different reviews, were some of those reviewers in the U.S. and some in Europe maybe?
That said, the U.S. market is by far the largest market for English layout keyboards, so while larger manufacturers may make separate versions for different markets, some manufacturers may just make one ANSI layout version and try to sell it everywhere. Who knows?
