Thunderdolt
- Oct 23, 2018
I'm configuring my alarms to trigger on high coolant temp, but am not sure how high to set that limit. Is something like 40C a normal temp to see, or is that in the "oh sh!t" warning range?
I tend to work and set up the machines to a max of 10C delta over ambient temp... usually 10C - 15C delta over ambient is considered normal.. I usually work with deltas as is not the same an ambient temp of 18C and a coolant temp of 35C as an ambient temp of 25C and a coolant temp of 35C..
This is interesting. I may have to rip out these ML120s and replace with something higher flow. I'm surprised that this setup can't quite keep up with the CPU. On this loop, the 300W CPU is the only heat source and the radiator is 360x60mm with ML120s in push-pull. CPU is currently holding 84C with coolant at 41C.
This also means that the GPU loops may be insufficient given that they have ~600W to dissipate and are only 480x60mm with ML120s in push-pull.
I would do it this way:
See what the delta T is between your CPU and water temp. Determine what maximum CPU temp you would be comfortable with. Set your target coolant temp based on that.
I mean....I guess a long as your components are at a fine temp it's okay. Personally, assuming you're at a normal room temp, that sort of temp delta is way too high for me.Thread necro...
I have a 5900x & 3090 FE on a single 420MM rad, water temps while keeping noise reasonable are about 45c.
Is that an OK Temp? If not it looks like I'm getting a new case and another Rad![]()
Thread necro...
Define OK. Are you getting performance throttling? Do you prefer your CPU and/or GPU load temperatures to be lower? Do you want to overclock higher, but can't because of thermals? If yes to any of those, it is not OK. If the answers are all no, then I don't see any point in spending additional money for something that will net you no tangible benefits.
If you want a reason to tear your computer apart and modify/expand it further... then the question isn't whether or not your temps are okay, it's how much satisfaction you will get out of working on your computer vs the cost put into upgrading it.
I'm lucky, my water temp at idle is 22c atm and maxes at 30c ish.that^^
10-15c over ambient is what you should shoot for, other wise youre killing the cooling performance. i set max fans at 35c water temp.
its the use of IHSs causing that. if water temp is low IHS temp is low and will handle temp spikes better. keep the IHS cool and the cpu stays cooler.The tricky part is the CPU. For whatever reason, I have found the benefits from a water loop to be much smaller when it comes to the CPU. This has been across several mounts with two different CPU blocks in the last 5 years. If you are looking for much improved CPU temps, this is where you really want a lower loop temp.
If you really cannot avoid high water temps, you should look at acrylic or other material. But really (for me I should add), water temps of 45c defeats the point of watercooling. Why throw hundreds of dollars at this to only get a few degrees better than air cooling?I think a number is what, 40C if you are using PETG tubing? Higher and it can deform. I know some vendors sell little plastic inserts to put at the ends of tubes to keep the rigidity if it does happen?
or worse. to the component is like sitting in a 45c room.If you really cannot avoid high water temps, you should look at acrylic or other material. But really (for me I should add), water temps of 45c defeats the point of watercooling. Why throw hundreds of dollars at this to only get a few degrees better than air cooling?
To be honest you could probably do better with decent fans. you could try flipping them around as well for the time being, fans usually perform better in push and especially bad ones do. If you want those bling fans you're gonna need tons of rad space to make up for the lack of airflow.I'm more worried about the pump dying to high temps(also noise) I already ordered a new case and 2 x 360 rads... this was a newish build, but I used my old Core P3 to build it in, which is limited to a single rad unless I use some 3d printed rad mounts. (at this point it looks a bit odd, and takes a way from the finish)
What rad are you using? My EK CE rads don't cool quite as well as I'd wished.I was thinking about getting some vardar fans, or ML140s, the Static pressure on these is not THAT much lower on the MLs, but even at full tilt, they are pulling a decent amount of air out of the rad, and it's hot.
That's a drag. What fans are you running with them?What rad are you using? My EK CE rads don't cool quite as well as I'd wished.
Currently a 420mm xt45What rad are you using? My EK CE rads don't cool quite as well as I'd wished.
I will give it a shot end of week when I hope I am finally up and running. It is a CPU only loop so I am hoping to see 70c peak... but I guess I don't have anything to base that on.As said above, it depends on what temp you want your components to run at. The best way is to put your system under full load (CPU and GPU) and see how hot your components are at each coolant temp.
That's close to what I have it set at currently. Silent until 35 degrees (GPU load pops it over 35) then it will ramp up to full by 42 degrees, it never crosses 42 with this setup, which is nice, but I really don't want to hear the fans at fullso I am also building a water cooled system, ordered a coolant temp sensor that my motherboard can see. I have fans that on low are around 800RPM, and would like the system to be quiet as possible for as long as possible (not ramp up and ramp down often). What coolant temp is good to start ramping the fans? I was thinking make a fan curve that starts at 35c coolant temp and is 100% fans by 40c. Ambient ranges from 20-30c depending on season, but would rather set it and forget it.
That is similar to how I have my radiator fan profile setup, but my fans start out at a higher RPM (1300 RPMs) and ramp up from there. For me and my case setup, 1300 RPMs I can barely hear them and these fans top out at 2200 RPMs. At 35C, they start to slowly ramp up to 1500 RPMs. By 40C they are at 1800 RPMs. If it ever gets too hot, they will max out at 2200 RPMs by 45C. Thankfully, in day to day use, it stays below 40C and I only ever see around 40-41C if I am doing an extended CPU burn test. The fans I am using are BeQuiet! SilentWings 3 120mm High Speed PWM fans. Their static pressure rating and noise levels spec'd out pretty well.so I am also building a water cooled system, ordered a coolant temp sensor that my motherboard can see. I have fans that on low are around 800RPM, and would like the system to be quiet as possible for as long as possible (not ramp up and ramp down often). What coolant temp is good to start ramping the fans? I was thinking make a fan curve that starts at 35c coolant temp and is 100% fans by 40c. Ambient ranges from 20-30c depending on season, but would rather set it and forget it.
okay so maybe I will try 35-45c as the fan curve. Once the rads are installed I will adjust idle speed to the highest speed I can barely hear. Gentle Typhoon 1850rpm fans.That is similar to how I have my radiator fan profile setup, but my fans start out at a higher RPM (1300 RPMs) and ramp up from there. For me and my case setup, 1300 RPMs I can barely hear them and these fans top out at 2200 RPMs. At 35C, they start to slowly ramp up to 1500 RPMs. By 40C they are at 1800 RPMs. If it ever gets too hot, they will max out at 2200 RPMs by 45C. Thankfully, in day to day use, it stays below 40C and I only ever see around 40-41C if I am doing an extended CPU burn test. The fans I am using are BeQuiet! SilentWings 3 120mm High Speed PWM fans. Their static pressure rating and noise levels spec'd out pretty well.
You should be aiming for a delta of 10c over ambient.That is similar to how I have my radiator fan profile setup, but my fans start out at a higher RPM (1300 RPMs) and ramp up from there. For me and my case setup, 1300 RPMs I can barely hear them and these fans top out at 2200 RPMs. At 35C, they start to slowly ramp up to 1500 RPMs. By 40C they are at 1800 RPMs. If it ever gets too hot, they will max out at 2200 RPMs by 45C. Thankfully, in day to day use, it stays below 40C and I only ever see around 40-41C if I am doing an extended CPU burn test. The fans I am using are BeQuiet! SilentWings 3 120mm High Speed PWM fans. Their static pressure rating and noise levels spec'd out pretty well.
