What is wrong with my iPad ???
Discussion in 'Apple Products' started by TechLarry, Jan 11, 2018.
  1. TechLarry
    TechLarry Pick your own.....you deserve it.
    28,624
    Aug 9, 2005
    I have an iPad Air Gen 1 on a swing arm in the kitchen. It's pretty much never been used off battery.
    The battery seems fine. At first thought it was because all the memory was used up (literally, zero bytes wer available for storage) so I cleared 16G.
    Nope. Didn't fix it.
    Rebooted. Nope. Didn't fix it. It went a way for a while but I can hear it's back agaijn.
    It's a really fast Bedoop Bedoop Bedoop sound every 1/4 second or so.\\If I unplug it the sound goes away.
  2. UnknownSouljer
    UnknownSouljer [H]ardness Supreme
    5,530
    Sep 24, 2001
    So, the problem is the sound?
    I would say, check the cable. Test a different one.
    EDIT: In case it's not clear, iOS has a chime that it makes when a device is plugged into a power source. A faulty cable makes it connect and disconnect constantly with power. Of course I don't know the exact sound you're referring to without hearing it, but considering that it stops making sounds when unplugged, it seems likely to be a cable issue.
  3. Agromahdi123
    Agromahdi123 Gawd
    659
    Jul 22, 2005
    yea sounds like the cable is connecting and disconnecting, check the charging icon, if it goes on, off, on, off, cable is bad that sound, Bedoop, is the "hey you plugged in a cable" noise, and the other one, is "oh you unplugged a cable'
  4. TechLarry
    28,624
    Aug 9, 2005
    The beep cycle is way faster than that.
  5. UnknownSouljer
    5,530
    Sep 24, 2001
    Did you try it?
  6. TechLarry
    28,624
    Aug 9, 2005
    Well, it's all silent now....
  7. UnknownSouljer
    5,530
    Sep 24, 2001
    Okay. Feel free to check back in if it has other problems.
  8. westrock2000
    westrock2000 [H]ardForum Junkie
    10,329
    Jun 3, 2005
    I’ve had this happen before. The lightning cable gets worn out over time. If you look at the actual pins you will probably find the middle pins to be blackened or dirty. That’s the ones that carry the voltage and they are very tiny, so they get destroyed after a while.
    Very common problem on lightning cables. Sometimes you can get some extra life out of it by flipping the cable over.
    But I have replaced many lightning cables over the years. Nearly all for this reason.
    Ocellaris likes this.
  9. TechLarry
    28,624
    Aug 9, 2005
    I'll replace that puppy just to be sure. I have tons of them lying around...
  10. mope54
    mope54 [H]ardness Supreme
    7,117
    Oct 2, 2004
    It's faster than you plugging and pulling the cable in and out but that's the speed of the interface losing/gaining connection.
    Like a flickering fluorescent compared to you flipping the light switch on and off--the flickering is going to be much faster.
