I have currently overclocked my Pentium D 955XE to 4.71Ghz (Air cooled) at 1.45V.
http://premium1.uploadit.org/ManojM//4.71Ghz.JPG
The CPU temp after benchmarks reads 50 degrees C.
I am not sure about the Pentium D 955XE but with my Opteron 170 overclocked to 3ghz (1.55V), the CPu temp was about 40 degrees C.
Does the Pentium D 955XE really run that hot?
I can also run the Pentium D 955XE at 4.41Ghz (Default voltage).
http://premium1.uploadit.org/ManojM//4.41Ghz.JPG
The CPU temp is not high at all when run at default voltage.
It seems that running at higher voltage over stock voltage raises the CPu temp quickly.
So keeping in mind that I am only using air cooling, what is the max voltage I should use to keep the CPU temp within safe temperature readings?
By the way I am using the Asus P5WD2-E motherboard.
