What is the "DVD Burner" to get?
fibroptikl
What is the best bang for the buck, with excellent quality? I know Pioneer, and Lite On and NEC make a good burner.
Any specific suggestions? I'll be using it to :gasp: burn DVD's of a bunch of data I have.
Thanks.
I am getting the toshiba 16x dual layer black DVD+-RW drive great price and toshiba has a good rep...I also like how quiet they are, and they look sleek and unobtrusive.
Anything by NEC. Great quality at a good price, with excellent media compatibility.
Or Pioneer DVR-108.. Same speeds as the NEC 3500A if you are a Pioneer products lover.
Thanks.
I'll give the 3520 a look at.
Oh, and my first thread in 6 years of intarweb to be moved.
End of the month or so. LG 4163B with faster RW speeds and 5X DVD-RAM is already out.
I plan on buying that drive, as it seems to have a big bang for the buck. But I have a few Qs, and these are really newbie qs...so bear with me :)
1 Can it read CDs?
2 Does it burn CDs?
3 Is it just as good, if not better then a CD drive?
Thanks.
1 Can it read CDs?
2 Does it burn CDs?
Thanks.
You could actually READ the specs of the drive... and get the answer yourself
From the first link (newegg product page)
NEC 16X Double Layer DVD±RW Drive, Black, Model ND-3500A BK, OEM
Model# ND-3500A BK
Item # N82E16827152032
Specifications:
Write Speed: 16X DVD+R, 4X DVD+RW, 4X DVD+R9, 16X DVD-R, 4X DVD-RW, 48X CD-R, 24X CD-RW
Meaning it WRITES DVD+r's at 16x, DVD+RWs @ 4x, .. etc.. You get the point?
Read Speed: 48X CD-ROM, 16X DVD-ROM
Meaning it READS cd-roms and DVD's
Wouldn't be a very useful drive if it could BURN cd's/dvd's, but not READ them, would it?
I picked up the Plextor PX-716A the other day. I must say, I am impressed. (LOL Lot of rhymes there.) 16x Dual Layer, Dual Format. I burned a full DVD@16x in no time. $100 at Best Buy after $30 MIR. :)
I just finally got a DVD Burner. I feel so behind in technology for burners.
I got the Sony dru-710a. $60 AR w/ Free 50pack DVD-R AR.
Just purchased an LG 16x dual layer burner, gotta figure out all this stuff all over again:D
Hey guys, a few more question as I'm looking to upgrade myself...
1. Do they make DVD-R9 or just DVD+R9? I heard that "Dash R" was in the works, and if this is true I would like to find a drive that can write DVD-R9 as well as DVD+R9.
2. Any suggestions with an 8mb buffer as opposed to the standard 2mb buffer?
3. SATA might be good :)
Anything that fits these?
^Plextor PX716SA.
One thing.. 2MB buffer will protect you for 1.5 seconds @ 1X DVD writing speed (1.355MBPs), while 8MB will protect you for 6 seconds. Therefore, 2MB v. 8MB buffer makes no difference.
The Plextor's expensive but does come with some nifty toys. I haven't installed my 716A yet, but looking at the manual it seems it's got some nifty software included with it.
The most interesting features (IMHO) are:
* GigaRec: Up to ~1GB on an 80-minute CD-R. Woah. The catch is it only works in DAO, disables burnproof, and won't read in a lot of drives.
* Burn error reporting. Tells you how many correctable errors have been made in the burning process. Nice for seeing how well a particular type of media really works in a particular drive. Burns with lots of errors may read more slowly and are more likely to wind up unreadable if scratched.
* Silent Mode: For when you just don't want to listen to a drive spinning at 48x.
Do NEC/Phillips/Benq/etc. do stuff like this?
Philips and Benq drives are essentially the same, and yes, Lite-On, Benq, Pioneer drives can use Nero CD-Speed to report the PI/PIF errors. You can use Drivespeed to limit the reading speed as well.
I will have to give another vote for the Plextor PX-716A.
The best feature I found out about this drive is that it burns my personal favorite media (TDK 8X DVD+R) at 12x speed.
I have a NEC-2500 DVD-/+RW drive and I find it doesn't read DVDs so great.. Every time I try ripping a DVD, DVD Decrypter gives me errors.. I use my standalone Sony DVD-ROM, no problems....
Just a thought
I did some research about which drive is the best and all signs pointed to the 3500A. So I suggested one to my buddy who needed a new burner. We put it in a did a bunch of ripping and writting and I must say the read speads on that drive suck ass. After a little more research (mostly at videohelp.com) I found that the drive comes riplocked which apparently limits how fast it can rip a DVD. You can flash it to solve the problem however. I wish I'd learned this before I recommended the drive to my friend :mad:
I think its still a nice drive but frankly its annoying when you have to flash a brand new product just so it will work as you expect. I should have just gone with a plextor rather than reading all those reviews.
-Marshall
Well if your all set in stone over the NEC, do yourself a favor and get the 3500A and not the 3520A. The 3520 has been known to be ploblematic. Although Id personally suggest the lIte-On, they ahvent done a wrong doing yet
