I am apparently out of the loop. Word on the street is that qrb is back in public beta. What is the ppd?
I also heard AMD cards are viable again. I would love to switch back.
Tell me everything.
Extra special thanks to our testers:
Jesse_V, k1wi, artoar_11, bollix, ChelseaOilman, bruce, Demonfang, Grandpa_01, EXT64, Flaschie, HayesK, jimerickson, mmonnin_, P5-133XL, Patriot, rhavern, sc0tty8, SodaAnt, SolidSteel144, EvilPenguin, art_l_j_PlanetAMD64, thews, cam51037, Pin, muziqaz, baz657, PantherX, QINSP, Schro, and hootis.
johnerz said:QRB is out on beta for both AMD and NV, it's a unified core 17, on open CL - that means that AMD now outshines NV in a very big way
a 7970 is almost double the ppd of a 680 - the 680 is now producing high 20's K ppd the 7970 high 40's k ppd
Good luck and its about time the red had its day (he says folding on 2 green GPU's)
The 5 series is also out performing the 6 series by a lot
a 570 is about 38k ppd
a 670 is about 27k ppd
both overclocked of course
So any idea what we're looking at for 5870 PPD yet? I will probly set it up this evening but a baseline would be useful to know if i set it up correctly. I'd guess from activate AMD's last post i should be seeing at least 20k out of it compared to a 7970?
This is just a beta, so production PPD is still up in the air.
You can run the benchmark program..
http://foldingforum.org/viewtopic.php?f=38&t=23440
Which will give you a very accurate idea of how any card will perform, relative to another. Remember that with QRB, PPD is not linear. In the link above, a 7970 scores 2.5x higher than a 5850, so PPD would be significantly less than 7970/2.5 (because of QRB), so well under 20k. I didn't see any posts for 5870, but I'd guess low teens...shrug.
Not wrong. From a dedicated folding perspective that does look like a potential ppd/$ sweet spot at this time. I think AMD's performance is notable because its finally where it should be, but also that its significantly better than nV's flagship 680. I'm just happy because I chose the 7970 over the 680 for cost and availability reasons when I was looking for a gaming gpu, and that decision has paid off for folding as well.So judging by this, the 570 is a steal right now. Why so high on AMD if 7970 only gets ~10k ppd higher and costs twice as much as a 570? That's roughly 25% upgrade in ppd for 200% of the cost. Am I missing something?
PS. Anyone have any numbers on a 580?
Ohh goody, GPU folding right before summer time.
Sacrifices, Sacrifices....everything here has been running flat out for 2 summers already
the downside for me...I was kind of looking forward to actually playing a game
You don't have to use the web interface. Select your folding icon in your task-bar and select "advanced control." Heck of a lot more options there.
PS. You don't even need to keep the web interface open.
Yeah I found the systray icon. I'm still concerned about the low GPU utilization. Do i need to add some client or core options?
Edit: bingo client-type = beta should do it. I'll see what it picks up tomorrow after it finishes this current one.
"FULL THROTTLE YO"
lol
BTW Ted, you are showing up on my threat list now...jerk
lol
Sorry for the n00b questions here. Figured if I had the question someone else might too, and I spent about an hour looking around for the answer and couldn't find it here or on foldingforum (or google). Maybe I'm looking in the wrong place.
Using v7.3.6
1. I'm assuming I add the " -beta" flag to the end of my shortcut filepath, but it just breaks the link and won't run. Which file exactly am I looking to add this to? FAH Control or Client?
2. If I run in -beta mode, will my GPU receive only Core 17 WU's, or will they be mixed in with other, lower PPD units? If the latter, it may not be worth the extra power for me.
System: Intel 2500k + AMD 6870.
*snip*
The main difference at this point is, due to driver issues, NVidia cards require a full CPU core , whereas AMD 7 series only require 1-2% of a core. So, with AMD you can get faster SMP times, or alternatively if not folding on CPU, get less total power draw.
Wasn't it only 6-12 months ago that this was the other way around??
I currently have a Core2Quad and Radeon 7750... a second Radeon 7750 for crossfire would be the most cost-effective upgrade for gaming... it's beginning to sound like it'll be good for folding again, too!
Yahoo!
How do you think a Radeon 7750 will perform? It's the fastest card out there that doesn't need extra power, so it may be an excellent choice for low-watt folding!
BTW - does downloading the new 7.3.6 give me this new performance?
EDIT: Hmmm... According to AMD Catalyst, only 50% of the GPU is being used, even on the "FULL" setting. I wonder what I'm doing wrong? The Core2Quad is running my 4 cores at about 90% each which is nice when still browsing the net, etc.
EDIT2: When bringing up the pretty spinning blobbies graphic, it mentions the core is 0x16... don't I need this new x17 core? How do I get/apply it??
Thanks!
Add client-type = beta to the flags under the expert options tab, client options. That allowed me to start picking up core 17.
