deathhorse
- Nov 29, 2010
Gonna re apply paste to my htpc video card what should i use? I have mx2 and some of that cremaqui stuff the white one.
Judging from that table, there isn't that much of a difference between the MX-2 you already have and the rest with the liquid metal pad being the one exception. I'd just use the MX-2 and call it a day.
I use Phobya HeGrease Extreme High-Permormance Thermal Compound (3.5g) on my CPU. When I apply it to my Sapphire 7950 I can't run stock voltage and clocks without thermal shutdowns. The old paste on the thing crumbled to dust when I opened it to see why it was overheating in the first place. What should I be using?
Also the heatsink is pitted like an acid burn victim. What caused that? Was like that when I looked inside so it's nothing that an outside source did. I'm figuring that's the reason that I can't keep the temps down. Or could there be another reason? The GPU core is a mirror finish so I assume that it's not warped in some manner like the heatsink.
I did buy an Accelero but a family member tossed the shims, heatsinks, and epoxy in the trash because he didn't know what it was. If violent crimes weren't punishable....
Slap a little mayo on there, maybe some toothpaste, call it day
It's not the best, but I just use Arctic Silver 5 on everything 'cause it's cheap and easy to apply.
It's conductive though, isn't it? I'd rather play it safer with one of the non-conductive pastes. I have some MX-2 around somewhere.
