What is the best 140 mm fan for silent water cooling ?
Lucky75
Hello guys,
1. Be quiet! Pure Wings 2 - 140 - 1600rpm High
2. be quiet! Pure Wings 2 140mm
3. be quiet! Shadow Wings 2 140mm
4. Bundle - 9x Noiseblocker BlackSilentPRO PK3 - 140mm (1700 rpm)
5. Bundle - 9x Noiseblocker NB-eLoop B14-PS Bionic Fan - 140mm PWM (300-1200 rpm)
6. SilenX Effizio - 140 mm - 12 dBa
7. Noctua NF-P14s redux-1200 140x140x25
8. Thermaltake Riing 14 LED RGB (140x140x25mm)
I think Silen Effizio - 140 mm is the best choice or probably Shadow Wings 2...
I have not had experience with anything else on this list, but I can say that the NB eLoop 140s are very quiet with a very pleasant noise profile. I've got nine of them on my MO-RA3 and they are wonderful.
D-EJ915
The best probably depends on how the fan blows through your rad and what kind of intake/exhaust you have more than just picking a random fan.
I had a full set of NBEs in my rig but the ones for my exhaust rad (pulling through rad exhausting through rectangle stamped grille) had pretty low airflow, I replaced them with some Arctic P14s and get much more airflow now. I'd tested them before with just the rad and they were fine so I think the grille is the issue but still for the price the P14 is awesome. They are pretty quiet too as well, I tried beQuiet SW3s in my case after noticing this and they were the loudest fans I tried through this grille lol.
Lucky75
I want to put 18 FANs in push/pull configuration for 3 radiators. I think that 300-500 rpms should be fine for under 20 DBa.
D-EJ915
If you're intending to run the fans that low RPM you'll need to make sure they actually work at that low of a speed, most don't go that low to be honest.
Nobu
I have some rosewill hyperborea 140s that are pretty good, but they can buzz/flutter at certain rpms. They're rebranded akasa apache fans, run best around 800-1000rpm, but the range is 400-1400 iirc. At max speed it sounds like a vortex (all wind noise).
Edit: range: 600-1300rpm, 12.5-22.2dBa, 89CFM max.
Light1984
I went noctua NF-A14 chromax. 300-1500 rpm and only 24db at max. Plus the static pressure is really good. Was comparing these to silent wings 3.
