What is the a6 similar to?
PCunicorn
I am going to get a very cheap gpu, because that's all I will be able to afford. Something around the 5450 area, and will get amd. The A6 games okay on my Lappy with 6640G grAphics, will the 5450 or 5550 be around there?
The absolute cheapest GPU I would try for gaming is the 6570. Anything slower than that and you may as well just use an APU.
I can't though. I will try for a 6570, but I wasn't planning for gaming or a permanent solution, just for a couple months.
You should be able to get a 6570 for $45 new, less for used obviously. I have one in my HTPC mainly for post processing on 1080p 60 fps videos.
