PAo_ReVoLT
- Apr 4, 2008
anyone has experience of ripping BD movie to ISO? What is average size?
thx
thx
I haven't ripped that many, but I would say around 30-40 GB on average.
if you re-author with clown bd to movie only prob closer to 20gb on avg
From the same source, the average video size is 26,800,000,000 bytes, plus 2,000,000,000 bytes for audio, plus 4% overhead for the M2TS brings it closer to 30,000,000,000 bytes per video. You're off by ~50%.. not too bad.
so if not ISO, how do i rip a BD in 1 file w/ menu and everything lossless?
thx
Excellent question. I being a nob have been wondering about this exact issue. You don't want lossless quality and you want to use the menus. An ISO is the only way I know of so far. If I understand it if you decrease the size you will lose quality, correct? The whole idea behind Blue Ray is the great picture and HD sound. So isn't creating container folders, transcoding/encoding to MKV tarnishing these features you bought Blue Ray for to be with? Might as well stick to DVD, no?
As I said I'm new at this and been somewhat confused during the learning process.
thanks
makemkv does not lose video or audio quality, from what I know.
but the m2ts default folder structure like a vob for DVD is 1 way.
I rip my BRs to m2ts in about 4gb files
This discussion regards a practice that is often illegal in operation.
*people often lie about their only desire to make backup copies of their own Blu-Ray discs.
yes but problem w/ makemkv is i do not get sub and menus
