Looking for a good reliable power supply to run the following:
Supermicro X9dai
2x Xeon E5 2680v2
4x 8 gb DDR 3 ECC for 32 gb of ram probably go up to 64 gb later for total of 8 sticks.
One super power hungry video card. Want the option to get a GTX 790 or whatever dual gpu card is out then if I want it for Star Ctiizen or other demanding game.
2 x solid state drive
6 sata drives to start probably will end up with 10 or 12 eventually.
2x pcie Raid card Areca or LSI for video raid and cheaper card like a Highpoint for the data raid 1.
pcie sound card
fans
maybe a front bay if I get a soundblaster again.
I put it into the the power supply calculator I found online and it said 849 watts for 10 drives and a gtx 690. 790 is not out yet.
http://extreme.outervision.com/psucalculatorlite.jsp
It recommended the following power supply
EVGA Supernova 1000 G2
http://www.amazon.com/EVGA-SuperNOV...6208&sr=1-1&keywords=evga+super+power+1000+g2
Is it worth getting the EVGA Supernova 1000 P2 for $20 more?
http://www.amazon.com/EVGA-SuperNOV..._sim_e_10?ie=UTF8&refRID=1YA9Y6HQCX1R1XQVAKGZ
Both of those look pretty good with the 10 year warranty and Jonnyguru review.
1000 w g2
http://www.jonnyguru.com/modules.php?name=NDReviews&file=print&reid=361
1000 w p2
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=361
terrabyte89 recommended a Silverstone 1kw power supply
http://www.amazon.com/gp/product/B0...pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846
Been buying PC Power and Cooling for years but they got bought by OCZ and went down the tubes.
Some real life friends were saying Corsair based on their experiences with the AX series but looks like Corsair discontinued the AX series and the new Corsair RM series is not very good from the reviews so what other options would you recommend?
Supermicro X9dai
2x Xeon E5 2680v2
pcie sound card
fans
1000 w g2
1000 w p2
