What is a cheap solution for replacement / repair Nokia Lumia 920?
Discussion in 'Smart Phones and Devices' started by Happy Hopping, Jul 13, 2019.
  1. Happy Hopping
    Happy Hopping [H]ardness Supreme
    6,614
    Jul 1, 2004
    I have a Nokia Lumia 920 for 5 year, the usage is about 6 min. / month. I also bought a Otter Box to protect it, that box is about $70
    In the past few months, it takes a much longer time for the phone to get signal. So after the phone is boot up, it has no bar, sits at emergency mode for many minutes, before it can get the signal. but some other times, it's instantaneous
    Switch to a new sim card, same problem
    The store told me it's the antenna that is failing although they said I can still do a factory reset
    Let's say it's the antenna
    My current problem w/ this phone is that at GPS signal for map (off map, no internet) takes about 10 to 15 min. to find the GPS signal, but again, some other times, almost immediately. I do remember that's the same problem 5 yr. ago
    I check ebay, I can get a new one for $66.49, and that seems to be the cheapest option.
    I can buy a new phone, the store recommend a cheap MOtorola G6 Play for $90, but then I need to buy another armor case.
    Should a Nokia Lumia 920, it's only a Nov. 2012 release phone, say buying a brand new one, takes 10 min. for the GPS to find its map signal if you don't have internet, so called off map option? Whereas some other time, it can find the GPS location immediately? I thought even in 2012, the technology should be good enough for the GPS to find the map signal immediately.
    Could this be my phone antenna problem since the beginning 5 yr. ago or does any Lumia 920 can take 10+ min. to find its GPS map signal?
    anyone has another other idea for repair or replacement? I just don't want to waste another $70 for another armor case
  2. Tup3x
    Tup3x [H]ard|Gawd
    1,848
    Jun 8, 2011
    It's totally obsolete device at this point (I have ditched mine ages ago). Honestly you should just buy a new phone. The battery life is horrible in Lumia 920 and the browser is so outdated that even websites will have trouble to function properly.
    Non assisted GPS takes longer to get a signal (though it's near instant on my Huawei P30 though, assuming that you are outside). I can't remember how the GPS was on my Lumia 920.
  3. Aurelius
    Aurelius 2[H]4U
    2,539
    Mar 22, 2003
    Honestly, I'd suggest getting a new phone -- and don't be afraid to spend more to get a phone that will last a while. The G6 Play is fine for the money, but I'd lean more toward the regular G7 for the faster processor and additional memory.
    The simple reality is that Windows Phone/Mobile is dead. Getting another Lumia 920 (or any other Windows phone) would preserve a familiar experience, but you'd really just be postponing the inevitable switch to another platform.
  4. DWolvin
    DWolvin [H]ard|Gawd
    2,017
    Nov 13, 2002
    Depending on needs, I just picked up a pair of Moto G7 Power phones. No NFC, but a huge battery and nearly stock android for $250~ish.
  5. entropism
    entropism 2[H]4U
    3,640
    Dec 23, 2004
    T4rd likes this.
  6. Happy Hopping
    6,614
    Jul 1, 2004
    well, thank for that moto casing tip. Let me see what my phone co. says on Mon.
    because that ebay guy lies to me. it's refurbish that he says it's new. 2 other dealership also said new, but they are $100
  7. Happy Hopping
    6,614
    Jul 1, 2004
    update: the cellular phone provider wants $150 from me on motorola e5 play.
    Now the local store tell me to buy a basic phone instead. I am open to suggestion. As long as the phone can do maps without internet, and I use about 6 to 10 min. per month, that's all I care about
  8. waderunner
    waderunner [H]ard|Gawd
    1,035
    Jun 2, 2013
    iphone se?
    I was a Windows phone guy for several years, and had a 920 myself.
    After enough apps had lost winphone compatibility, I went through the same dilemma of deciding what next.
    I ended up with an iphone se
    Hadn't had an Apple producct since the original iMac. But the iPhone SE has been a really good replacement phone for me.
    Maps work without data (Google Maps), fairly inexpensive device (often under $150 for a carrier locked one). I got an ATT locked SE, and use it with AirVoice Wireless. Has worked great for me.
    And particularly because I like the smaller, pocketable size of the SE, compared to the mondo 5 and 6 inch phones.
    And I can pass for a normal person, now that I have an iPhone :)
  9. Happy Hopping
    6,614
    Jul 1, 2004
    I can't stand anything w/ Apple
    what other brand are there? and do I have to go w/ ebay? Is there some website that focus on cellular phone?
  10. radeon962
    radeon962 [H]ard|Gawd
    1,199
    Mar 13, 2008
  11. T4rd
    T4rd [H]ard as it Gets
    16,486
    Apr 8, 2009
  12. Happy Hopping
    6,614
    Jul 1, 2004
    but wait a minute, when I check w/ several dealers at ebay on nokia lumina 920, they said they are all refurbish, as NOkia has been gone for so far, there is no new phone. So how can you be so sure about the nokia 6 NOT being refurbish
  13. T4rd
    16,486
    Apr 8, 2009
    Not sure what you're talking about.. the 920 and Nokia 6 are two completely different phones running completely different operating systems and were released at different times. I think the Nokia 6 just launched last year, whereas the 920 launched in 2012, so yeah.. you're not going to find any new ones.
  14. Happy Hopping
    6,614
    Jul 1, 2004
    I thought the brand Nokia went belly up? the dealer at the store told me so, is it still own by microsoft?
    what about a brand call Alcatel, any good?
    anyhoo, w/ my Nokia 920, I have this "Off line map", and the robot lady walk me thru step by step of where to go, and I do NOT have internet or any pay DATA feed from my cellular phone provider. And all these years, it works very nicely.
    w/ that in mind, what's a reliable "Off line map application" that works? Because it seems to be a free service that connects me to the satellite, and from my GPS location, tell me where to go from point a to point b.
    I don't want to buy a brand name that will go belly up and lost this feature
  15. T4rd
    16,486
    Apr 8, 2009
    It didn't go "belly up", it was sold to HMD.
    You can use the Google Maps (or many other map apps) app for offline navigation if you save your area for offline within the app.
    Nokia as we know it doesn't seem to be going anywhere anytime soon, but you can't predict when about company may be sold off or whatever either. Your only completely safe bet to avoid this is with Samsung, Apple, LG, or maybe Huawei. But I wouldn't worry about it considering you're looking at sub $150 phones that get minimal support regardless, but these are Android One phones too, which are pretty much good for 2-3 years of software support regardless. So I wouldn't worry about it really.
    DWolvin likes this.
  16. DWolvin
    DWolvin [H]ard|Gawd
    2,017
    Nov 13, 2002
    ^ This. The Moto phone I mentioned is on the high end of what you are looking for, but the huge battery is pretty cool (No NFC, but I bet you won't care). For cheaper smartphones, you really have to choose Android or iOS these days, and they are both decent if you are not invested in one or the other. LG and Motorola are pretty light on the changes to Android, and usually good at keeping up to date on patches. But any of the Android One platform phones are running basically straight Android OS and will get very fast updates.
    The only other one I'd offer is the Essential Phone, but it's getting old. That said it's a near-flagship running stock Android. It had Pie the day before the Pixel phones. I love mine and am going to be sad when it goes, there really isn't a replacement right now.
  17. Happy Hopping
    6,614
    Jul 1, 2004
  18. DWolvin
    DWolvin [H]ard|Gawd
    2,017
    Nov 13, 2002
    Near-field communication, it's how the Android 'tap and pay' system works, among other things. Really short-range wireless that is supposed to be more secure than Bluetooth.
  19. Happy Hopping
    6,614
    Jul 1, 2004
    I don't need that function. As long as Motorola can provide the off road driving direction by that robot lady, and it's accurate, and that I can dial out, I'm happy
  20. Happy Hopping
    6,614
    Jul 1, 2004
    So I found the Nokia 1 that seems to do what I need: off line map and dial out
    But when I go back to ask the sales person on off line map, noone can answer this question:
    6 yr. ago, when I got the phone, the salesman download the google map of the local city and nearby area, and since then the robot lady guide me on driving direction from my current GPS location to the desitnation, now:
    WHO PROVIDES THIS FREE SERIVICE? AND WHY?
    as I have no internet feature or data feed on my phone, it's a straight dial out phone plan, I never pay for data feed or internet services or text messages.
    I thought it's Nokia or my cellular phone co. that provides this service , but today, the sales person said no on both companies
  21. Happy Hopping
    6,614
    Jul 1, 2004
  22. pendragon1
    pendragon1 [H]ardForum Junkie
    13,982
    Oct 7, 2000
    if a map is preloaded it only uses gps which is free, no data needed.
  23. T4rd
    16,486
    Apr 8, 2009
    If you want a considerably smaller screen (seems counter intuitive for navigation), 1/4 of the storage (8GB is more like 5GB usable too, which is less storage for map data, I wouldn't count on using an SD card either for app/map data as that's barely ever supported), and significantly slower phone (also counter intuitive for anything - I wouldn't ever recommend a phone with only 1GB of RAM now either even for light usage), then yes, you can save a buck on that Nokia 1. The value is a lot better for the specs you get on the 6, but if price is absolutely top priority, then go ahead on the 1 you link there. You're getting 1/3 of the phone for half the price for sure though.
  24. Happy Hopping
    6,614
    Jul 1, 2004
    tell me more.
    1) I only need to store 1 regular size city map, plus some very small nearby area.
    2) what is the purpose of 1 GB of RAM? I only need to dial out
    3) why do you say it's a slower phone? It can't be slower than my 6 yr. old NOkia 920 boot up, can it?
  25. T4rd
    16,486
    Apr 8, 2009
    Nah, just buy it then.
    I'm not here to sell you a phone and I already gave my opinion on it. But I will say that I wouldn't be surprised if that phone was slower than the 920 considering Windows Phone in general ran better than Android, esp. on lower end hardware. So just buy it and you can always return it within 30 days if you're not happy with it.
  26. Aurelius
    Aurelius 2[H]4U
    2,539
    Mar 22, 2003
    You can choose the areas you save offline maps for in Google Maps. They don't take up much space, but be sure there aren't gaps in coverage.
    On RAM... you know your Lumia 920 has 1GB of RAM, right? This is temporary memory, and smartphones need quite a bit of it just to keep running smoothly. 1GB is considered modest by today's standards (many Android phones ship with 4GB, 8GB or even 12GB of RAM).
    Boot up might be one thing in terms of performance, but the fluidity of the interface and app performance might be another. Windows Phone was well-known for running well on modest hardware, and for keeping its performance well over time (even if what it could do was limited). With Android, that's... not so true. It's getting better, but there's still a huge difference between, say, a Nokia 1 and a Samsung Galaxy S10.
    Also, while I wouldn't want to press the issue, it might be worth looking at a phone plan with basic data. You don't want to be stuck without directions if you have to venture outside your coverage areas and can't stop at a place with WiFi.
    T4rd and pendragon1 like this.
  27. Happy Hopping
    6,614
    Jul 1, 2004
    oh, I didn't know that. I know almost nothing about cellular phone
    for the price difference, I can move to this:
    https://www.gsmarena.com/motorola_moto_g6-9000.php
    the Nokia 920 has something like 26 GB of storage space. And I used up 1 GB only for the local city map
    so if the above Motorola phone can dial out fine, then do you guys think off line map will run smoothly ? The Nokia 920 off line map run very smoothly all these years. And I didn't pay for data or internet.
  28. Happy Hopping
    6,614
    Jul 1, 2004
  29. viper_0307
    viper_0307 Limp Gawd
    225
    Apr 8, 2016
    My last Windows Phone was Alcatel Idol 4s. I have been though many Windows Phone; going back to Motorola MPx220, HTC Titan, HTC Pure, etc... When announcement came out, it was an inevitable switch to Android.
    Picked up a Moto G6 (4GB/64GB) last November; finally running Pie.
    I recently went on Amazon and picked up a UNIDIGI Power for about $140 before tax; came with Pie; superior in specs to the 3 Motorola phones you listed.
    If from your list: G6 > G6 Play > E5.
  30. AltTabbins
    AltTabbins [H]ard as it Gets
    19,189
    Jul 29, 2005
    G6 if you want a higher resolution screen.
    G6 play if you want a bigger battery.
    Pick between what is more important to you. Maps will run fine on either.
  31. Happy Hopping
    6,614
    Jul 1, 2004
    for those who uses Motorola, does anyone has a link on a list of service center in North America on their phones?
  32. Haste266
    Haste266 [H]ardness Supreme
    7,431
    Sep 27, 2005
    I had been using a Nokia Lumia Icon(929)Black with Verizon for over 5 yrs. The wife and I have been hemming and hawing over new phones but didn't want to pay for a top of the line, or even $300-400 for mid-range. I stumbled upon the Motorola G7 Power for $120 at Verizon! 5000mah battery, screen is lower res but still looks decent, and the camera is not so great but I don't really need that. We got the phones last night and I have been very impressed. I've been out of the game so long though that this is the newest tech I've used in a quite a while.
    Thanks for the thread!
  33. Happy Hopping
    6,614
    Jul 1, 2004
    okay, so I start using the Motorola E5 play, download the offline map, but Google send me a mesg. saying if my map is NOT updated by Sept. 11, it will be deleted. Now the map is just downloaded, so it's updated, what does the above means?
    are they seriously asking me to download the same map month after month?
    can anyone help?
    because my old nokia phone has the same map for 6 years.
  34. Tup3x
    Tup3x [H]ard|Gawd
    1,848
    Jun 8, 2011
    If you want offline maps, use HERE WeGo or something else like Sygic.
  35. T4rd
    16,486
    Apr 8, 2009
    Yeah, Google offline maps are only good for a month or two before it has to be updated. There are alternative map apps that don't require this or you can just connect to WiFi (any public AP or just hotspot your phone) and it should update automatically if it's expired.
  36. Happy Hopping
    6,614
    Jul 1, 2004
    are these software good? because I always wonder, it's free satellite service, why would they provide it? who's paying for these services?
  37. Aurelius
    Aurelius 2[H]4U
    2,539
    Mar 22, 2003
    Google subsidizes its maps with its search ad business. It's worthwhile to Google to provide map data and services if it encourages businesses to list themselves online and, of course, run ads.
    For others, it varies. Apple doesn't have much of an ad business, for example -- it sees its mapping app more as a selling point for the hardware.
  38. Happy Hopping
    6,614
    Jul 1, 2004
    in that case, who's subsidizing HERE WE GO or Sygic?
  39. T4rd
    16,486
    Apr 8, 2009
    Ads for HERE WeGo, just like Google and 95% of the other apps on the Play Store.
    Sygic is a paid app (only free for 7 days), so you are subsidizing it directly in that case.
  40. Happy Hopping
    6,614
    Jul 1, 2004
    what a small world. In my Nokia 920, that's the same software. But there is no ad., as it was the beta ver. I wonder if there is a way to get the old beta ver.
    w/ the old ver., the robot lady tells me where to go, I don't really view the screen, so if there is ad. on the screen, it shouldn't bother me
