Nazo
- Apr 2, 2002
My grandmother's computer has nothing but temperature issues. She insists on hiding it from, well, herself, so she has it inside this cabinet. You tell me why... Anyway, the point is that it's running pretty hot. According to motherboard monitor, the chasis temperature can go up to 37C or so. Maybe occasionally even more. The HD would fly up to high temperatures as well, but I think I've gotten it cooled down enough now. Anyway, I realized after I finished up with everything that it just has passive cooling on the northbridge. But I'd have to take the motherboard out to get the stupid things holding it in place out, and right now I'm just not going to be playing around with someone's motherboard (especially since I can't find a screwdriver that doesn't have at least some magnetic properties.) So, I'm wondering, do I need to switch that out the next chance I get? You see, we've had issues with her computer before. Specifically I made a long recording (trying to convert her old cassette tapes to CDs) in the area of 200-300MB, and the file was crashing every program I tried to use it in. Finally, I tried to make a copy and windows said it had a cyclic redundancy error -- which is pretty rare on a harddrive... I ran chkdsk and it took about an hour finding errors left and right. Well, I may or may not have cooled it down a bit. So, I'm wondering, is it possible that the chipset running too hot could have caused some of this, or is it for sure purely the harddrive? Oh, and the CPU isn't a problem btw (it's one of those older Intel P4 2.4GHz CPUs) so you don't have to be worried about it.
I'm thinking I might break out the epoxy and at least put one of my little heatsinks on her southbridge. I know it controls the HD among other things, so theoretically it might be possible it got too hot. I haven't decided for sure though since the southbridge isn't supposed to be able to get very hot normally (though, in my case, it definitely does as it is the limiting factor when I change my FSB.)
