{NcsO}ReichstaG
- Aug 13, 2004
None of the new cards feature "Video In." I liked this feature because I could hook up my Dish receiver directly to the computer with it....but if I upgrade....
What cables are good for that input, think thats on the 2900pro which is on the way, but never used VIVO before.
Composite/s-video is horrible on a PC monitor, pick up a card with component input and you get a much better picture.
And were would the average consumer buy such a card?
pretty much any modern card with vivo should have a component capable input output. it only looks like an S-video connection, but it has extra pins in it and it should come with a dongle that splits out into the RGB. as of the X19** series, ATI's partners still had many vivo cards available. most of the 1950pro cards had it.
WRONG-O
Those are component OUTPUTS, my friend.
There are pretty much NO affordable solutions for inputting high definition or even 480p into your PC at the moment. S-Video and composite are the best you'll get unless you want to throw down some serious cash for some kind of custom professional hardware.
WRONG-O
480i is easy enough for less than the cost of a high-end card, as per my link above. The most cost-effective solution for HD is the Holo3DGraph, but prices are highly variable - $500-$900.
