I was looking for a place to compare GPU specs and what all these different models were. With all of the series numbers I don't know if there is a card exactly the same in the 8 series as in the 9 series for nVidia cards that was just renamed or offered the same performance but cheaper.
I need 2 cards to run 4 monitors or 3 ranging from 20-30 inch screens.
I dont specifically have a budget set yet.
I am gauging how much things will cost and if it is worth it.
Well, lets see.
9800GTX == 8800GTS 512mb + higher clocks + Tri-SLI support
9800GX2 == 2x8800GTs in SLI (just remember only 1 monitor works with SLI)
GTS 320mb/640mb == skip these - they are beaten in performance by cheaper cards
8800 Ultra > 8800GTX > 8800GTS 512mb (all 3 are pretty close from what I remember - GTS 512mb is the newer G92 core and uses less power but has less vram and bandwidth, GTX and Ultra are older G80)
8800GT > 9600GT (but both have similar price/performance ratio)
That help? (someone please correct me if my info is off )
