I managed to get another Geforce 7950GX2 card go pair up with my XFX Geforce 7950GX2 XXX Edition. At first I thought that it may not work since one is a factory overclocked card while the other is an the Nvidia reference card.
Anyway, both worked just fine but I am not sure what clock speeds they are running at. I check in the control panel and it shows under the overclocking tab that my GPU and memory clocks are at the same clocks speeds like the XFX Geforce 7950GX2 XXX Edition (570mhz core and 775mhz mem). Not sure if both cards are running at that clock speeds or not. Whatever it the clock speeds are, they are working fine and stable.
I am using 91.31 drivers.
I have tested in 3Dmark already and it seems that 3DMark 2006 shows a slight improvement with Quad SLI. May be about 10%. That is not much. In 3DMark 2005, there was no improvement with Quad SLI. In 3DMark 2003, there was a very good improment with quad SLI.
So Quad SLI works in 3DMark 2003 (well) and 3DMark 2006 (little) but not in 3DMark 2005.
In games I have only tested FEAR and the performance with Quad SLI is much better than just with a single Geforce 7950GX2.
Now I want to know how to set the image quality higher in FEAR (eg. 8x FSAA and 32x AF).
Which other games to test with Quad SLI and how to improve the quality settings? In the drivers or the game settings?
