I plan to build a cheap low power pc. My intentions for the pc is to have it on all the time and basicly have it downloading things around the clock and also having it so I can remotly access my music from work. Here is the setup i'm debating on, what do you think?
http://www.newegg.com/Product/Product.asp?Item=N82E16822144107
Western Digital Caviar WD1200BB 120GB 7200 RPM 2MB Cache IDE Ultra ATA100 Hard Drive - OEM $66
http://www.case-mod.com/store/via-epia-10000-epia-m10000-mainboard-with-1ghz
-cpu-p-1590.html
VIA EPIA M 10000 EPIA M10000 Mainboard with C3 1GHz CPU$159
http://www.directron.com/stratacase.html Black/Silver XMachine Strata
MicroATX / FlexATX Mid-tower Computer Case, w/ 200W Power Supply, Front USB,
Audio Ports $29.99
http://www.newegg.com/Product/Product.asp?Item=N82E16820145026
CORSAIR ValueSelect 512MB 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200)
System Memory - Retail $33.70
As far as I can tell the 200w psu that comes with the case should be enough.
I'm trying to keep power consumption down to a minimum. Any thoughts, comments or suggestion would be great.
-cpu-p-1590.html
Audio Ports $29.99
