what could cause such blurry text at 2560x1600?
Discussion in 'Displays' started by Happy Hopping, Apr 17, 2015.
Thread Status:
Not open for further replies.
  1. Happy Hopping
    Happy Hopping [H]ardness Supreme
    6,578
    Jul 1, 2004
    My friend has a HP Z30i that can support 2560x1600 at 60Hz
    the embedded video card is doing 1920x1200
    So I first upgrade to an old Nvidia Quadrdo FX370, it supports 2560x1600 just fine, but the text is very blur
    So I then switch to a Nvidia FeForece 8600GT, once again, it can do 2560x1600, but the text is blur, and when I open a small windows like the Advance setting tab under Display adapter, the text is unreadable.
    So I then screen capture the text and saved in a PNG file as proof.
    I now bring back those 2 video cards w/ the same DVI cable home, and test it on another PC and connect it to an slightly older HP ZR30W, which also can run 2560x1600
    The video card can display 2560x1600, and the text is crystal sharp.
    I then view those 2 capture text PNG file on my own PC, shockingly, the text is ALSO Crystal sharp, eventhough I can't see it at all on that HP Z30i
    In other words, I CAN see the text very blur, but the Screen Capture Display saved PNG files shows just fine on another PC
    Now, what is causing this? EDID?
  2. Zardoz
    Zardoz 2[H]4U
    3,251
    Aug 27, 2000
    Play with your refresh rate, also if you have mutable displays make sure they are both at the same refresh rate.
  3. John721
    John721 [H]ard|Gawd
    1,623
    Mar 8, 2006
    Any results when (re)running cleartype tuner?
Thread Status:
