What can cause this type of display corruption?
Erebus
I have a new-ish VisionTek 7970 that seems to have a display corruption issue. I'd say once every one or two days I will be working at the computer and all of a sudden this happens (on one monitor OR the other):
Rebooting fixes it immediately. I can be doing absolutely nothing when it occurs (sitting at the desktop, surfing, etc)
Any ideas?
Serpent
Wild guess, but it seems like a driver problem. I think I had something similar way back and rolling back drivers fixed it.
Ajiki-kun
I've been following this issue since I sold off my 7950 (which may or may not be related to your problem), in hopes that new drivers will fix it one day.
http://hardforum.com/showthread.php?t=1709338
http://www.overclock.net/t/1037034/how-to-fix-dual-monitor-screen-flicker-ati-amd-guide
I've also had the display crap out on me (but not system hang, like I first thought). Majority of the time it was browser-related, but a couple of times was when I opened video files.
Does any of this sound familiar?
Erebus
I have seen it occur more often than not with video files..Thanks for the information, I'll start looking through it
Ajiki-kun
dave3533, what Catalyst version are you using?
I am personally interested in finding out if this is still an issue even now, because I would still like to own an AMD card, but I will not buy one as long as this issue persists.
BababooeyHTJ
I have this happen too. Thankfully I've only had the full lock up like that twice. Its usually just a few bars flashing up. I notice that I didn't have that happen with the latest 12.11 beta, probably because of the card not downclocking with that driver.
rtangwai
Are you connecting directly to DVI or are you using DisplayPort adapters? My adapters occasionally crap out and I have to unplug and plug them back in to reset them.
Erebus
One monitor is plugged into DVI, one is plugged into HDMI via a HDMI to DVI adapter. The corruption occurs on both monitors (and never at the same time). Unplugging the monitor while this is happening does not resolve the issue.
Uncle
I let amd do their auto update with those drivers and the previous,I started to have problems of the rendering of windows onto my desktop slowing down. Couldn't correct it. Uninstalled and reloaded 12.4 and everything went back to normal. If it aint broke don't fix it.
crzykid71
That looks familiar to me from a past card years back.. not good at all, possible vram failing... it will only get worse & stay that way if that's what it is.
Erebus
*Update*
Upgrading to Windows 8 appears to have resolved whatever underlying issue was causing this.
Nocens
Oddly I had one of my displays do this the other day for the first time. I was using the same drivers as you.
wand3r3r
*Update*
Strange. I'd already be close to the RMA button.
That's good it solved it, it must have been software (windows or drivers).
