felix88 said:the fan they use isn't that noisy, and you can order a quiter fan if you like.
i wouldn't depend on your PSU to be moving air out of your case anyway. they aren't really designed to move more air than is needed to cool themselves.
Vertigo Acid said:"Good Reviews" meaning what? Did they actually do any real testing ala silentpcreview.com, or just the normal "it looks nice and works, I used MBM..."
I would definitly take the enermax noisetaker over the coolermaster anyday
xonik said:not qualified to evaluate power supplies beyond the usual, "well, this looks solid" or "the voltage looks okay in this one measurement."
They aren't old enough to have any sort of long-term reliability statistics, but I've heard many positive comments on them. BlindedByScience, one of the General Hardware moderators, seems to swear by them.SearchForTheAnyKey said:Does anyone know anything about the reliability of Thermaltake PSUs e.g. their PurePower line? No one seems to mention them, and I can only find one review online (although it's a very positive one...).
Actually, he swears by the butterfly line; From the buzz i've heard around, it appears that the >480w Tt are different and crapier than the <=480w models. YMMVxonik said:They aren't old enough to have any sort of long-term reliability statistics, but I've heard many positive comments on them. BlindedByScience, one of the General Hardware moderators, seems to swear by them.
I think's it's actually the PurePower line; oh well, the search isn't working quite right, and it doesn't matter anyway. That's strange about the Thermaltake rumors you're hearing; well, at least the thread starter isn't looking at power supplies beyond 480 watts.Vertigo Acid said:Actually, he swears by the butterfly line; From the buzz i've heard around, it appears that the >480w Tt are different and crapier than the <=480w models. YMMV
PSU.... one of the most overlooked and most important component,
that old 300 watter you have from your old duron 800 don't even try.PSU's have caused alot of trouble with a64 systems, they use alot of power Get a good name brand psu if you can, and make sure it is at least 400 watts and has at the minimum of 20a on 12v, also look at combined total wattage
the psu must have a 20 pin connector and a 4 Pin( Square) Connector, and there is Only 1, Called the+12V 4 Pin Processor Connector.
some of the recomended brands are enermax,and antec.
Here is the reason most problems are the psu
amd64 uses 12v power, intel chips used alot of 5v power.
so until now most big psu's pushed 5 v not 12v
almost everything in your computer uses 12v except ram (3.3V)
amd 64 and motherboard =12a @12V
so your already at 12A with no fan,s no hd, no cd,no dvd ,no mobo chipset , no mem, no sound..etc
so what happens is your mem gets starved for power and then gives out errors,in your data, which = corupt sata,or it fails to post. .
Vertigo Acid said:Wheres the real specs like ripple and regulation
Or how about a real under-the-hood review?
Seems to be a nice PSU with split rails and all, I wonder who OEMs it?
And Tagan is produced by Topower, right? I know their high-end P6 line (OCZ Powerstream is a Topower P6) is badass, but what about their mid-range P5 line? KevC is most likely looking at canadacomputers.com, and they carry some Topower P5s.xonik said:You should also see if there is a Tagan power supply available in that range at your retailer.
computerpro3 said:Just to let the thread starter know, the pc power and cooling 425 deluxe is hands down the best performing psu in that wattage range, and the pc power and cooling 510 deluxe is the best performing psu period.
The reason people keep reccomending other brands is because of two things:
1. Publicity and sales. Ever see a pcp&c add? I haven't.
2. Pc Power and Cooling are priced according to their quality
However, take it from me, I have tremendous psu experience and once you get a Pc Power and Cooling, you NEVER go back.
burningrave101 said:The reason not everyone recommends PC Power and Cooling is they are overpriced. A PSU for a $100 less can perform almost as well if not as well as the PC Power and Cooling and you'll be extremely lucky to ever notice a difference.
The 510 PC Power and Cooling is also very loud. Its one of the loudest out there running at around 44db i believe.
Most of PC Power and Cooling's parts are also manufactured by Fortron Source so you'd be better of just buying a 530w Fortron.
