Most enjoyable post in this thread so far. SMG in her prime
I don't understand what you're asking for. You do not believe that a single-GPU solution will not exhibit zero inter-frame latency in games?Single-card differences in frame latency consistency? Show me three games with proof of this, from two or more review sources please.
If what's most important to you is how high the frame counter in the corner of your display is occasionally reading, you probably need to re-align your perceptions about what's important for real-time rendering vis-à-vis gaming.I care about absolute performance
Why?We're talking about single gpu on a single display here. That seems off to me.
Even single card vs. single card I found the GTX 680 4GB cards to be smoother than the Radeon HD 7970's. I didn't expect it when I made the switch. I was just hoping to get my multiGPU setup working. Of course now months later AMD's resolved the lockup issues I had on the X79 and X58 platforms.
i been saying this for years now, i left amd/ati due to their erradic fps and choppy gameplay regardless of their 100000fps game benchmark showings.
Thats exactly why I sold my 4870x2 and kept my GTX280. I haven't found microstutter to be a major issue this gen. Even Cayman was pretty smooth for me.
I noticed the uneven frame times easily when I owned 79xx cards (radeon) versus switching to the nvidia 670 and 680 cards single card to single card. The nvidia setups were smoother and more consistent. The radeon setups felt juddery even when the fps count showed it was supposedly similar. High speed videos and frame time #s only show this more clearly than subjective observations like mine.
According to the early techreport GTX680 and 670 reviews 7970 and 7950 was actually smoother.
I didn't notice any difference in smoothness with a single card. I have noticed microstutter more often in crossfire but its not that often and generally not consistent but I don't use eyefinity.
I also find it odd that they never made a peep about the vsync stutter issues that some people still suffer with.
How on Earth did you get that incorrect conclusion out of this article: http://techreport.com/review/24051/geforce-versus-radeon-captured-on-high-speed-video ? It very clearly, both through graphs, written observations, and high-speed video capture, shows the GeForce cards are far smoother even at about the same framerates, overall.
How on earth did you misunderstand the post you were quoting. Earlier reviews. EARLIER REVIEWS.
This isn't some massive problem that's only now coming to light. You haven't been preaching the truth, and you aren't suddenly vindicated. It didn't exist as recently as a few months ago. It may not even exist now.
GoldenTiger said:No, I'd have you believe they have reported frametime info for years and AMD has almost always been on the losing end, which is completely true and can be looked at on TechReport's site for yourself. This current article is about the 79xx series Radeons (not older ones), and clearly they are even worse than prior generations. I'm sure if they had concluded the Radeons were superior, you wouldn't be saying the only two possible realities were that they "messed up" or "a bug". Other sites and people have carried out frametime checks over the years as well, this is not some radical new theory but a hardened, reality-proven method of testing cards in conjunction with framerates.
No one mentioned "earlier reviews" where I was responding.
No one mentioned "earlier reviews" where I was responding. What are you talking about?
Indeed this isn't some massive thing only JUST NOW coming to light, it's been known for quite a number of years amongst the more technical enthusiast communities of computers and technology.
I'll just quote myself for you from the other thread you posted something identical in:
Ugh, why do I need to see this just as I'm about to open my Gigabyte 7950 that I've been waiting for a free day to install? All I really care about is smoothness with the best eye-candy possible. Should I be considering waiting for an Nvidia card? This thread is a jumble already.
Personally I wouldn't return it because if the supposed issue didn't exist in August there has to be a reasonable explanation and if nothing else use the drivers from then if you experience any issues.
In general across the web the 7950 clearly outclasses the 660 ti especially at higher resolutions, even [H] agreed with their evaluation.
AMD cards didn't show any frame latency issues in their august review because those use older drivers that lack all of the recent performance increases. If you have to revert to using older drivers, you lose all of the performance increases also.
Due in a large part to the performance increase that came from the latest beta drivers, the same beta drivers that appear to have introduced the frame latency issue. It's interesting to recommend reverting to older drivers to avoid the frame latency issue, but then point to performance numbers using the newer drivers when talking about which card is faster. Can you really have it both ways?
Let's all not forget that the 7970 gets stomped by the GTX680 using any driver up until the recent betas (the ones that cause the frame latency problem). It was only then that the 7970 became commonly accepted as a faster card for most purposes. I just wonder if people would still have gotten that same impression if they had known up front what they had to sacrifice in terms of gameplay smoothness by using those drivers.
TechReport's previous reviews showed the GTX 560 Ti / 570 with very high latencies, way above the Radeons, so why did no one raise a stink then? Hmm? Seriously, can you people be any more biased?
Fanboys will be fanboys.
But some people are still getting it regardless of the keyboard.Solved: Replaced Keyboard.
bought a new logitech USB keyboard as my old one was ugly and replaced my PS2 Keyboard.
why there was lag i have no idea.
Thank you all for your helpful comments and hope you all resolve your issues too- i cant believe i built practically a new PC and it was the damned keyboard >.>
