What Am I Doing Wrong? Self-Signed SSL Cert Import
svet-am
For starters, I have a self-signed cert that I'm using on my self-hosted server. I have *successfully* imported my cert into Internet Explorer on a PC and it's working just fine there. Interestingly, I had to import my cert directly as a trusted CA Authority for it to work (don't know if that's important).
My target device is a BlackBerry Z10. I have imported the certificate successfully and I see it listed in the "My Certificates" area. That said, when I go to my domain in the browser, I get the "Site Identity Not Verifiable" error with a specific reason identified as "The certificate to identify <my_domain> has not been verified by a trusted source."
I clicked View Certificate and all of the details match the certificate that I imported. I've tried power cycling but that didn't help.
Am I missing something obvious?
That's correct. SSL certificates serve two purposes, firstly to setup secure transfer, the second is to verify the website identity.
Self signed certs provide the encryption, but as the source isn't from a trusted (from a certificate authority), it's not possible to verify the identity so you get the warnings.
Here is how I did it using openssl:
--- Creating a CA that you install as a Trusted Root Authority ---
1) Setup CA folder structure:
mkdir CA
chmod 0700 CA
mkdir CA/certs
mkdir CA/private
echo '1000' > CA/serial
touch CA/certindex.txt
2) Create openssl.cnf configuration file:
Code:
dir					= .
[ ca ]
default_ca				= CA_default
[ CA_default ]
serial					= $dir/serial
database				= $dir/certindex.txt
new_certs_dir				= $dir/certs
certificate				= $dir/cacert.pem
private_key				= $dir/private/cakey.pem
default_days				= 365
default_md				= md5
preserve				= no
email_in_dn				= no
nameopt					= default_ca
certopt					= default_ca
policy					= policy_match
[ policy_match ]
countryName				= optional
stateOrProvinceName			= optional
organizationName			= optional
organizationalUnitName			= optional
commonName				= supplied
emailAddress				= optional
[ req ]
default_bits				= 1024			# Size of keys
default_keyfile				= key.pem		# name of generated keys
default_md				= md5				# message digest algorithm
string_mask				= nombstr		# permitted characters
distinguished_name			= req_distinguished_name
req_extensions				= v3_req
[ req_distinguished_name ]
# Variable name				Prompt string
0.organizationName			= Organization Name (company)
organizationalUnitName			= Organizational Unit Name (department, division)
emailAddress				= Email Address
emailAddress_max			= 40
localityName				= Locality Name (city, district)
stateOrProvinceName			= State or Province Name (full name)
countryName				= Country Name (2 letter code)
countryName_min				= 2
countryName_max				= 2
commonName				= Common Name (hostname, IP, or your name)
commonName_max				= 64
# Default values for the above, for consistency and less typing.
# Variable name				Value
0.organizationName_default		= My Company
localityName_default			= My Town
stateOrProvinceName_default		= State or Providence
countryName_default			= US
[ v3_ca ]
basicConstraints			= CA:TRUE
subjectKeyIdentifier			= hash
authorityKeyIdentifier			= keyid:always,issuer:always
[ v3_req ]
basicConstraints			= CA:FALSE
3) Create the CA cert and CA Private Key in the CA directory above (My CA is the name of your CA):
openssl req -new -x509 -nodes -days 18250 -subj '/CN=My CA' -newkey rsa:4096 -keyout private/cakey.pem -out cacert.pem
4) Create the Cert Request and Private Key (/CN is the name of the server):
openssl req -config CA/openssl.cnf -new -nodes -subj '/CN=server.mydomain.com' -newkey rsa:4096 -keyout server.key -out server.req
5) Create the server Cert:
openssl ca -config CA/openssl.cnf -days 3650 -out server.crt -infiles server.req
Install the cacert.pem on the device as a Trusted Root Authority. Install server.key and server.crt on your webserver. Since cacert.pem signed the server.crt the device will trust it.
********** OR **********
--- Creating a self-signed cert ---
openssl req -x509 -nodes -days 3650 -subj '/C=US/O=MYORG/CN=server.mydomain.com' -newkey rsa:4096 -keyout server.key -out server.crt
Install server.key and server.crt on your webserver. Install server.crt on your device as a Trusted Root Authority since self-signed certs are created with CA true. Apache will complain that the cert is a CA cert because of this, but will otherwise function normal.
