I got this for $599.
BE WARNED: this is a piece of shit for use as a monitor. Read thread over at AVS, and pay close attention to my angry posts. Lots of buggy ass issues with HDMI ports, image scaling, contrast and brightness auto adjust, even updating firmware etc.
Ive only had 1 problem using my 42" version of this TV as a monitor. When in 1080p mode, the sound input via the VGA jack wont work. As soon as I bump it down to 720p works great.
If you're hooked up through VGA with a .4843mm dot pitch, I don't know what to tell you. Maybe you haven't noticed the other issues because your picture is too blurry to see that while scrolling over dark backgrounds, the screen gets brighter and vice versa. You can't shut this off. No firmware update fixes it, if you can even find a flash drive that works with the USB port to update the firmware. The HDMI ports are hubbed and autosourcing works as well as Hellen Keller in a Marco Polo match.
Not to mention the panel itself has terrible contrast and displays piss poor blacks, if you even call them blacks. I call them purples.
Keep in mind the TX version is the piece of shit. LVM is (was) fine.
HOW ?
I have autosource DISABLED and Dynamic Contrast DISABLED and power saver mode DISABLED.... as a result the TV just plain works.
I run my XB360 in VGA mode with this TV and I got sound.Ive only had 1 problem using my 42" version of this TV as a monitor. When in 1080p mode, the sound input via the VGA jack wont work. As soon as I bump it down to 720p works great.
