Digital Viper-X-
- Dec 9, 2000
! it scares me, maybe I'll keep that northbridge fan on high,Good luck with that.
did you ever have any aftermarket nb coolers? like the HR sli one installed?
I have the C00 version, which can't run the quad cores.
These threads are so depressing... my eVGA has been good to me, but I have the C00 version, which can't run the quad cores. I'd like to get a new board, I've been thinking Striker and water cooling the CPU/GPU, but with these kinds of posts being so common, it makes me question whether stepping up to a Q6600 is worth the potential hastle. I should just slap water on my current rig on water and call it a day.
My eVGA has been good to me, it's been stable as all hell since the day I bought it... I should just sell one of my vid cards and go X38 with a nice hardware RAID.
Thanks a lot, Dan... you got me all depressed
Actually...the C00 CAN run the Q6600's. That's what I'm running right now, STILL waiting on EVGA to send my A1 revision (which they did, and it was a POS so now they're sending me another...only it's a "BR" version...).
I think whether or not your C00 board will run the Q6600's is sort of a crap shoot. Mine seems nice and stable even overclocked the q6600 to 3ghz. However...it won't go 1Mhz more no matter how high I set the bus speed and lower the multiplier (or play with voltages). My friend on the other hand that has the same board and revision, had all kinds of problems running his Q6600 even at stock speeds. He recieved his A1 board and all is fine now.
I'm thinking of Getting the Abit IP35 Pro or the Abit QuadGT X38 board after the holidays and Ebaying this one. I see a LOT of good things about the IP35 Pro, and to be honest...I don't think I'll ever use dual video cards on a system but if the x38 board is close in price I'll get that just to support PCI-E 2.0.
If you are looking for higher overclocks and you only feel you need one video card, then by all means. Going with X38 is absolutely the way to go.
So if I were going with an x38 board... and was willing to pitch in the ~$70 difference between an IP35 Pro and the x38 board... would you recommend the Abit QuadGT X38 or the Asus Maximus Formula? The only advantage I see to the Abit (maybe it's not really an advantage) is a totally digital PWM power circuit for the CPU where it looks like the Asus is using an 8-phase design.
Looks like both boards are very comparable. Both also use DDR2 so I can use my same memory. I've owned both brands in the past, multiple boards from both actually. And I still use 2 A8n32-SLI Deluxes at home and love them. But then again...I'm still using an Abit BP6 for my firewall box
Just got my A1 in from EVGA today to replace my AR for "proper" quad core support. I must say...this A1 board BLOWS ASS. It's not even stable at STOCK speeds...let alone ANYTHING above stock.
Thanks to EVGA and Nvidia, I've made my decision to dump this 680i garbage and go with a P35 or X38 chipset.
I'm sure the 680i is fine with dual cores, but apparently quads just aren't meant for it. I swapped the board and booted - no drivers loaded...ok, fluke...reboot...all the drivers load. I was thinking great, up and running right? wrong. Bsod and reboot...then it hangs at the bios screen. So I reset cmos, get into bios, set it for BELOW stock settings and reboot...flash to P31 bios. Slight improvement...a little more stable at stock speeds. At least no BSODs...just IE closing, games exiting to desktop, crap like that. So I blow away vista and reinstall...same damn problems.
What I did notice though is that at stock...the drivers load...at anything OVER stock...they don't. It boots up and puts me in "punishment mode" with 800x600 res and 16bit color. If I set the speed back to stock or below, windows loads fine (most of the time) but just has problems RUNNING ANYTHING.
so..yeah...whatever...I have enough headaches with my job...don't need them with my PC so Nvidia can kiss my rear on their chipsets. What the hell happened anyway...their stuff was top notch on the AMD side. I'd almost swear I was using a frickin' SIS chipset in here.
Hey dan, see if you can get a hold of a skulltrail board. That would probably be the best board for you .
my EVGA 680i is 11 months old now, and it never gave me any trouble at all! guess i'm a lucky sob.
x2
However I did kill my 2GB modules after making a mistake when overclocking.
Also my USB on the back is wierd, when I plug my G15 into the very top one and my G5 mouse right next to it, the mouse will not show up when Windows XP boots.
But if I switch the mouse to the USB slot below it, it works great.
Tomorrow I plan on installing Vista x64 and throwing in an additional 2GB of PC2-6400 Crucial Ballistix Tracer and another 8800GT when it arrives. Hopefully this move will be problem free. Heres to hoping anyway....
I'd like to know what your NB temperatures are. Take readings with any software you want, and let me know what the BIOS says as well. My guess is that your readings will be nearly 20c higher than they should be. If so we might be able to narrow some of the 680i SLI problems down to the 680i silicon itself or possibly to voltage components on the board.
are the "normal" A1 boards crazy as hell? I mean, I just got this one in from EVGA to replace the AR...and for the life of me I can't get it to run stable at stock speeds. However, if I bump the fsb by about 15-20mhz it works just fine. Hell, right now I'm running at 3.63Ghz on this Q6600 @ 1.4v (with vdroop mod)...been running that way since about an hour after my last post and I've run Orthos for a while, played some Crysis, surfed the web, watched the screensaver, played some COD4 with an Orthos running in the background....solid as a rock when I overclock the piss out of it...but at stock speeds it's about as stable as a hippo on a highwire. 1066fsb is unstable but 1080fsb is. 1333fsb is unstable (was perfectly stable on the AR) but 1350fsb is. 1600fsb is unstable but 1623 is.
very strange.
I have the fan attached to the 680i northbridge heatsink and Everest is telling me the MCP temp is 55º C. CMOS claims the same thing. 131ºF
Here are photos from when I first pulled the heatpipe cooling off and replaced with AS5.
http://picasaweb.google.com/drjester/EVGA680iThermalpasteGoop
Just installed Vista x64 and everything so far is going pretty smoothly.
4GB of Crucial Ballistix Tracer is awesome!
the MCP temp on mine is reported as 48c. What's the "norm" considered?
:EDIT: I have the fan on mine also, but it's only set to 70% speed.
I am a seasoned computer tech and I am troubled by the amount of problems many are having with this 680i motherboard. I recently last year built my friend a brand new system with the latest hardware. We now have to do a fourth RMa on the same mobo due to double dashes on the board(flatline as i call it).
I do not know if it is an XFX problem as well, but it happens to be on EVGA boards. Nvidia does make the chipset and as such there could be design flaws with the northbridge. Many times companies pass the buck to others but ultimately someone has to fess up ot maybe cover their tracks.
I did notice on the new 780i mobos that they have a cooling fan over the northbridge heat sink. Now this obviously is a slight improvement over the 680i.
I know many of us have to buy after market products to keep the temps cool in the system but can't these manufacturers instead of taking the easy way out, provide all you need in the boards and contents that come with them.
I feel that research by the company needs to be done and that they should aloow users who have documented problems with the 680i upgrade to the 780i for free to help compensate for the downtime many suffer. Not all of us have big money to build 2-5 rigs.
Dan is right I think in the northbridge is the culprit. If you check EVGA site as they tout the new 780i, you will see a fan on the northbridge made by nvidia.
Comspiracy possibly or it jsut a way for nvidia to cover the flaws in their design and hush it up and pass the buck onward.
It boils down to obviously better quality control and more thorough testing by manufacturers before releasing their products. I know many people have damaged boards on their own I am sure but a majority of us take care of our rigs since we put our heart and soul into building them.
