Well constructed external USB3.0 to SATA drive bay
Dmitri
Can someone please recommend me a decent USB3\Esata sata drive bay. I have a whole bunch of 7200 drives I need to use with my laptop. It seems all the external drive bay products I buy break after a few weeks use. The construction is terrible on these things.
I have two currently, both brands I presumed were decent.
A Welland Leopard (http://www.welland.com.tw/html/USB3.0/601S.htm) The on\off switch no longer functions. I've taped it into the on position and now power it on\off by pulling out the power plug.
Icydock MB881U3-1SA SATA/IDE USB 3.0 (http://www.icydock.com/goods.php?id=130) The connector to the cable on the device itself is weak and no longer works (unless the cable is propped up very carefully pushing the connector into a position where it decides to actually..connect). Rubbish.
Neither of these devices suffered abuse, they weren't moved around much essentially just sitting on my desk.
Are there any extremely durable external drive docks that someone has experience with and can recommend? I want to get years and years out of the device, not 2 months.
Old Hippie
Looks like he's looking for a drive dock not a drive enclosure although that particular unit is unusual and if you don't have IDE drives that's just more stuff to fail/present a problem.
OP, Icydock has a good rep. for quality and it's just the luck of the draw you got a bad one.
The Thermaltake series docking stations have always been reliable.
They have many different configurations USB/eSATA, double and single slot.
Good Luck!
FuSoYa
Lurker
I'll second the Thermaltake BlacX docks. I have two of the USB 3.0 docks, one at home and one at work and have not had any problems with them.
parityboy
Can you clarify that part? You're right about the DS321 being unusual though, it's as solid as an enclosure and very nearly as convenient as a dock - you can hot swap drives very easily, especially if you leave the front off. :D
Dmitri
Good Luck!
Thanks, I'll take a look at that Thermaltake product.
I own an internal Icydock 5x 3.5 inch drive bay and it's built like a tank. It seems the minute these companies produce something that's not meant to be hidden away inside a case they get cheap and spend too much time trying to make them look pretty rather than robust.
