Ok, here's the deal:
Got a GIGABYTE GA-770TA-UD3 AM3 AMD 770 SATA 6Gb/s USB 3.0 ATX AMD Motherboard from Newegg, and some Crucial Ballistix DDR3 RAM, as seen here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148323&cm_re=crucial_ballistix_ddr3-_-20-148-323-_-Product
My first build using this setup works great. So I needed to build a second computer, and I bought the same parts again. The thing is, the newest motherboard will not run more than one stick of the stuff at a time. Each stick individually works perfect, but with 2 its just a long beep, pause, long beep, and it won't boot. I tried the sticks from the first build in the new motherboard (same motherboard as the first build) and I get the same problem. Both motherboards are running the same bios as well. It seems something changed with the second motherboard, even though they are the same revision. However, I noticed the markings around the front panel headers are a little different, so its like they revised things a little, but not enough to call it a new revision. I've tried setting timings manually, upping voltages and such as well, still not working. Should I just write this off as an incompatibility issue that can't be resolved?
