Nerdface Killah
- May 31, 2013
We have a Brocade GS648P switch which has 3 vlans on it. One being a generic vlan, the second is "management" but should be actually data and then there is a third which is our voice. There are certain ports that are trunked and in vlans 2 and 3 (voice/data). If you plug a computer into the pass through port of a voip phone you see upload speeds of 50-100Mbps. If you plug a computer directly into a switch port which is only on vlan 2 (data) you see 10/10 pretty much consistently. The main issue is that we have a Synology nas that we want to be backed up to Amazon S3 and when plugged directly into a vlan 2 switch port it takes a really long time.
I've swapped out the router with a basic DD-WRT router and it still happened. The router is a SonicWALL TZ100 with no services running at all. We have a ESXi host with three guests, one Exchange, one AD DC, DNS, DHCP and a file server.
I've looked high and low into the Brocade for qos, port throttling, acl rate limiting etc. but literally nothing is set except for all ports are trust dscp enabled. I have tried disabling it on a single port but it didn't do much.
Any ideas why a computer connected to the pass through port of a phone would allow it to utilize our full connection speed? We have fiber to the building. Thank you in advance!
