Weird GFE glitch
Discussion in 'nVidia Flavor' started by Ramses, Oct 7, 2018.
  1. Ramses
    Ramses [H]ardness Supreme
    5,395
    Jul 30, 2000
    Anyone seen this? Started in the last few weeks, un/reinstall same same. Does it on all screens, logged in or not.
  2. sk3tch
    sk3tch [H]ard|Gawd
    1,452
    Sep 5, 2008
    Are you using any kind of network filtering? For example, pi-hole will block some of the domains that GFE needs to "phone home" and communicate metrics back to NVIDIA (which can be considered a violation of privacy, hence why it is blocked by default).
    Armenius likes this.
  3. Armenius
    Armenius I Drive Myself to the [H]ospital
    19,358
    Jan 28, 2014
    Can't say I have, and I had to login again after I updated to the 416.16 driver last week.
  4. Ramses
    5,395
    Jul 30, 2000
    Nah no filtering, other than what win8.1 does by default. It's worked before for ages, just started this at some point in the last few
    months. I've reinstalled it a couple times here and there, it's the same when logged in, weird double windows, pretty unusable.
    No other issues with the full time use PC, gaming or all day at work.
  5. Sprayingmango
    Sprayingmango [H]ard|Gawd
    1,259
    Jan 20, 2012
    Have you used DDU to do a full, clean reinstall each time? I always run DDU first then install my graphics drivers.
  6. Ramses
    5,395
    Jul 30, 2000
    I did this last time going from 1060 to 1080, full DDU with reboots and ccleaner and the whole rigamarole.
    It's been screwed up long before and still is after.
  7. Ramses
    5,395
    Jul 30, 2000
    FIXED, set GFE to ignore screen scaling and bam, kinda fat looking but it works fine now. NV tech support was also stumped when I tried em this afternoon.
    Armenius and cybereality like this.
  8. cybereality
    cybereality [H]ardness Supreme
    4,861
    Mar 22, 2008
    Great end to the story. I'll keep that in mind.
  9. Armenius
    19,358
    Jan 28, 2014
    Huh. I use 150% scaling and never had this issue.
