Web Content monitor
Chimay
Does anyone know of any free solution you can place just before our firewall in an office that would monitor all traffic? I'm looking for something that would basically monitor what users in the office are doing with a connection into AD / DNS to resolve the IP to a machine name or username.
firedrow
You can setup Untangle as a transparent bridge to do this. Just need a workstation or server with 2 NICs.
plupien79
Untangle will indeed do this. However... The free version doesn't support Active Directory.
k1pp3r
Also in my experience with untangle, even with standard paid version, it doesn't do a good job of logging what sites a person visits in a readable way. Their logs are a pain in the butt to go through.
Chimay
Thanks for the recommendation on Untangle. I'll take a look at it. Does anyone have any suggestions on a paid product that they use in their organization that does basically the same thing well?
Nicklebon
Many firewalls will do this if configured to do so. What firewall is your office using?
Chimay
Its a small office and we're using Cisco 5505 ASA. I know we need to upgrade the firmware but I haven't seen much for this specific web content monitoring in it. I've heard of bluecoat but it looked fairly expensive and I've read mixed reviews on it via forums. Does anyone use bluecoat actively that could provide input on it?
Nicklebon
The asa is by far my weakest platform and has what I consider to be the worst logging features in the industry. That said, I think you can at least get url logging with client IP by using http inspection.
Personally I'd dump the asa in favour of a Fortinet, Check Point or Juniper box asap. IMHO they each offer a richer set of features. better logging and reporting options, better performance, plus tighter AD integration.
Nate7311
Fortinet would be a great solution. Reasonable cost of entry and great support too!!
bracut80
we were running websense web security for the last 3 years until this year when i upgraded firewalls from watchguard to Fortinet. The fortinet handles web filtering with no issues and since it is a UTM, that module comes with it and can be turned off or on. it saved us quite a bit of money not having to renew websense.
MrGuvernment
When was the last time you used it?
it shows everything fine for me well laid out, in the Reports module you see the system or user, check by site sizes, block, visited..
live logs show the same thing...
we have the untangle premium here paid for, $1200 a year i think and i get every bit of info every single person on my network does.. as well as a full UTM.
try it out, you can get the full premium trial for 14 days...
But i would say run untangle in Router mode, toss it on a server dual core or quad, and 4-8Gig of memory and watch it run!
sinisterDei
How big of an environment (number of users) are you looking for?
At the small end, we've had better customer satisfaction with control & filtering options than with reporting.
