- Nov 14, 2004
Soooooo... why do I want to put four of these in a PCIE x16 adapter and see what happens so badly, lol.
WD Black SN850X 8TB | Sabrent Rocket 4 Plus 8TB | |
Sequential read | 7,200 MB/s | 7,000 MB/s |
Sequential write | 6,600 MB/s | 6,000 MB/s |
Random read | 1,200K | Up to 700K |
Random write | 1,200K | Up to 1,000K |
$600 dayum. I got my Sabrent 8TB almost a year and a half ago for $999. Now that same model is $1100. It's odd: the plain stick is $1200, the version that comes with the Heatsink is $1100.
Google says:
The Sabrent Rocket 4 Plus is based on BiCS5, while the WD Black SN850X uses TLC flash.
Great, now I need to find out what BiCS5 is.
The WD drive is a little faster:
WD Black SN850X 8TB Sabrent Rocket 4 Plus 8TB Sequential read 7,200 MB/s 7,000 MB/s Sequential write 6,600 MB/s 6,000 MB/s Random read 1,200K Up to 700K Random write 1,200K Up to 1,000K
He compares the 2: But chances are, based on the new price, the WD would be the goto choice. EDIT: This video is a few years old, might be talking about the 4Tb WD which has different performance characteristics. Looking for better reviews...
View: https://www.youtube.com/watch?v=OIyixTGFyuM
Google says:
There aren't many reviews out for the 8TB SN850X. I looked into it prior to snagging two for $550 each during that sale on their direct Sandisk website. The good news is, unlike many other drives that lose a chunk of performance with the extra NAND, these drives only saw ~100MB/s drop for the read speeds (thanks to the newer BiCS6 NAND and slightly upgraded controller) compared to the 4TB SN850X version (that has BiCS5 NAND) is what I pulled out of the two reviews that I found:
https://www.tomshardware.com/pc-com...8tb-ssd-review-the-no-compromise-8tb-champion
https://www.tweaktown.com/reviews/1...-ssd-the-new-king-of-high-capacity/index.html
EDIT - what really impressed me was the sustained write performance that didn't drop even after 2.5 minutes of writes View attachment 692337
What’s the bad news?Random reads are what matters for most app loading times. Being 80% better is not "a little".
Here are both of mine with stuff already on it with NVME SSD selected under settings (sorry, didn't get an empty test):Does anyone have one of these that can run a CrystalDiskMark bench on it?
why is our two middle tests so radically different?Here are both of mine with stuff already on it with NVME SSD selected under settings (sorry, didn't get an empty test):
Did you select NVMe SSD under that settings drop down? I upgraded to 8.0.5 and got results within the margin of error compared to my 8.0.4 results.
ok the NVMe SSD selection helped, thank youDid you select NVMe SSD under that settings drop down? I upgraded to 8.0.5 and got results within the margin of error compared to my 8.0.4 results.
Thanks. Could you change 2 settings and re-run the test?Here are both of mine with stuff already on it with NVME SSD selected under settings (sorry, didn't get an empty test):
My results were already set for NVMe SSD in the software.Thanks. Could you change 2 settings and re-run the test?
Click Settings, then select the nvme SSD option, then click Profile and select Real World Performance:
This is what I got on my 83% full 8TB Sabrent Rocket 4 Plus:
Oh really the 8tb is faster in speed?I also picked one up - moved all of my photos onto it. Editing RAWs is noticeably faster than when I had them on SATA 870 EVO 4TBs.
Yes, NVMe gen 4 is quite a bit faster than ol' SATA, to the point where it makes a major difference in many real-world applications.Oh really the 8tb is faster in speed?
Windows loads noticeably faster on a decent PCIe drive, compared to SATA. Let alone everything else.Yes, NVMe gen 4 is quite a bit faster than ol' SATA, to the point where it makes a major difference in many real-world applications.
Oh I thought we were talking about the same SN850X 4Tb vs 8TbYes, NVMe gen 4 is quite a bit faster than ol' SATA, to the point where it makes a major difference in many real-world applications.
Yeah, friend of mine called and insisted his all in one (Win10) was infected.Windows loads noticeably faster on a decent PCIe drive, compared to SATA. Let alone everything else.
I saw more difference going from NVME NAND to Optane than I did from SATA NAND to NVME NAND.Windows loads noticeably faster on a decent PCIe drive, compared to SATA. Let alone everything else.
I saw more difference going from NVME NAND to Optane than I did from SATA NAND to NVME NAND.![]()
Not sure. I see conflicting reports. Some say it does while other say it has HMB. I don't see why it would not be using DRAM.Interesting, the 8TB doesn’t have DRAM like the smaller capacities?
The 8TB’s on BiCS6 tooThe 1, 2, and 4TB version show as having a controller with DRAM enabled, so I'd wager that the 8TB does as well.
My friend in discord reached out and got a response, KarateBobThe 1, 2, and 4TB version show as having a controller with DRAM enabled, so I'd wager that the 8TB does as well.
EDIT - I can totally search databases properly... So, here is the 8TB SN850X version that shows it having a DRAM cache.
