wd blue 1tb ssd or samsung 850 evo 1tb ssd?
Discussion in 'SSDs & Data Storage' started by AndreRio, Dec 7, 2016.
  1. AndreRio
    AndreRio [H]ard|Gawd
    1,240
    Nov 23, 2011
    i need to buy a ssd. which one do you guys recommend? wd or samsung?
  2. Bandalo
    Bandalo 2[H]4U
    2,660
    Dec 15, 2010
    Samsung for now...The WD SSD's are still fairly new to the market, and I'd personally give them some time to see how they do before I spent my cash. Samsung has a long and successful history with SSDs already.
    RogueTadhg and {NG}Fidel like this.
  3. AndreRio
    1,240
    Nov 23, 2011
  4. drescherjm
    drescherjm [H]ardForum Junkie
    14,446
    Nov 19, 2008
    I would consider the crucial mx300 as well. Although prices are increasing now because of the shortage.
  5. AlphaFox
    AlphaFox Limp Gawd
    294
    Jul 26, 2016
  6. ep0x73
    ep0x73 2[H]4U
    2,563
    Sep 5, 2013
    Hard to go wrong with Samsung, still waiting for Crucial to have something that competes with them.
  7. AlphaFox
    AlphaFox Limp Gawd
    294
    Jul 26, 2016
    Samsung makes their own flash chips so kind of hard to compete
  8. drescherjm
    14,446
    Nov 19, 2008
  9. AlphaFox
    AlphaFox Limp Gawd
    294
    Jul 26, 2016
    Crucial = Micron
    {NG}Fidel likes this.
  10. ir0nw0lf
    ir0nw0lf [H]ardness Supreme
    6,313
    Feb 7, 2003
    Is price a factor for you? If not, the Samsung 850 EVO all day long. If price does matter, then toss up, big price difference that might be a factor to you.
  11. AndreRio
    1,240
    Nov 23, 2011
    Price is not matter this time. I just want to get rid of my mechanical drives!
  12. drescherjm
    14,446
    Nov 19, 2008
    Get the 2TB MX300.
  13. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    6,291
    Jan 17, 2005
    I'm looking at SSDs now myself. Crucial 2TB is mighty attractive and for the most part i doubt I'll notice the difference on performance between it and Samsung. The thing I'm wondering about the most is just how much more reliable are Samsung's versus the mx300 series. I capacity versus reliability basically
  14. drescherjm
    14,446
    Nov 19, 2008
    I would expect to have less than 0.5% Annual Failure Rate for either.
  15. HDriscoll
    HDriscoll Limp Gawd
    416
    Jun 18, 2012
    I've had no issues with any of the Samsung SSD's I have purchased.
  16. StealthNinja007
    StealthNinja007 n00b
    25
    Oct 13, 2010
    I've had a couple of the crucial mx series about 3 years ago, and a 2 or 3 samsung evo series. Never had problems between them, use them all the time... never benchmarked them either. IIRC, speed is supposed to be comparable, but Samsung would win at transferring lots of small files.
    The Crucial drives have the appeal of a better warranty - There's a thing called like Total Bytes Written. For most SSD's the warrant covers a rather low value. Crucial scales it the larger the drive gets. I used to do toooooons of backing up, copying, and database work on my SSD, so this mattered to me. I highly highly doubt it matters to you - I think the number is like 20 GB written a day for 3 years or something like that... and I think Samsung increased their number recently, and even if they didn't the prices have come down enough that if your drive dies out of warranty it should be easy to replace.
    I know the crucial also has the bx200 series, which I think has been discontinued? It's their low-cost line for large businesses. If you find that line of SSD's, they'll usually be a tad slower, but much cheaper.
  17. cmanser
    cmanser Limp Gawd
    383
    Feb 11, 2010
    Samsung for ultimate speed - Crucial for better price.
