Hey all,
I am looking for a good radiator made by AlphaCool perferbly but I will settle for another good brand to mount in the HAF-X I will be cooling only my CPU and Geforce Titan.
Anyone know which would fit? I'd perfer to stick with 120mm fans as nothing else really mounts. I know the HAF-X has mounting holes for a triple rad.
Would this fit ok ? Also how do I go about using the Compression Fittings 7/16 x 5/8" and which tubbing (Doesn't matter the color to me)?
I have a pump already the Swiftech MCP35X that I bought pretty cheap.
This is the radiator I had my eyes on. If a 240mm Rad would do the trick for the video card and cpu. My ideal wishes would be, not sure if it's practical to get the temps lower than 42C idle 55c load (76c LinX) "This is the CPU" towards 35c below w/ ambient @ 27C pretty constant on my H100i I'd be content. Also would like to get below the 65C under load on the Titan so I can possibly overclock it one day down the line or at least get rid of the blower that sounds like a jet engine...getting down to mid 50's with my video card during the summer...which is coming soon...Below the link to the rad I had in mind.
I'll be using Corsair's SP120 Quiet Edition fans to cool it. I have 8 of them.
http://www.performance-pcs.com/cata..._info&cPath=59_457_667_1075&products_id=37001
I have a 5.25" XSPC Res, if I need to get a different one, I guess I would...
Here's the Waterblock i'll be getting.
http://www.xs-pc.com/products/waterblocks/cpu-waterblocks/raystorm-cpu-waterblock-intel/
Thanks for your help in advance. I haven't done water cooling since hmm.. back when it first came out, I was real young. With all the stuff now and how to get it in the case with reasonable temps just puzzles me.
Sincerely,
Reticulex
P.S. My case dimensions and such. Would be nice if I found a fellow HAF-X owner here. I am cooling the stuff in my signature.
http://www.coolermaster.com/product.php?product_id=6653
Sincerely,
Reticulex
