Ok here is the deal, at work we have a wireless network that is authenticated via a RADIUS server with WPA encryption. A certificate authority issues a certificate based on the user/workstation being a member of an AD group.
All that works great, but it makes the initial setup tedious. With my current XP image, I have a simple batch file that fires off upon the first boot to setup some simple options and settings. This is an interactive script and the tech imaging the machine inputs the data. Ideally, I would like to add a step where it would ask "Setup wireless connection?". If the tech choose to do so it would automatcally setup the connection with all the appropriate settings.
Anyone know if this is possible?
