DarkenReaper57
- Oct 2, 2003
Hello all,
This may have been addressed before, but I'd like to confirm before purchasing any components. Here are my questions:
1. Is the Sapphire Toxic HD6950 2GB a reference layout (thereby supporting aftermarket coolers designed for this reference layout)?
2. I have a switech MCW-60 (not MCW-60R, if that matters) that I plan to reuse from my 8800GT. This is compatible, correct?
3. I'll need to cool the memory, PWMs, etc with separate heatsinks. I have some ramsinks (Enzotech type IIRC) that can be reused as well. These should be sufficient, correct?
4. Would I be better off using individual sinks or purchasing a Swiftech uni-sink (assuming I have a reference layout)? My worry with those large uni-sinks is there is always variation in component height due to fabrication tolerances, so perhaps some chips might not make proper contact. That said, there is more copper/aluminum to spread the heat, so cooling performance might be better.
Thanks!
Thanks!
