Now that I've gotten a GTX 980 Ti (which does run hot), it has re-sparked my interest in watercooling. There really isn't anything wrong with air cooling, but with the drastic increase in heat output, there are literally two potential goals I have that I think watercooling will get me.
1. Removing the heat and dumping it elsewhere.
2. Removing fan air noise.
For #1, I know that it can only be as cool as ambient allows. My goal with #1 is to use quick disconnect fittings directly outside the PC because I would literally have hoses running from the radiator/pump which will be in a different room altogether. This means that I will be able to store the radiator/pump in a, let's say, server closet or something, which means NO NOISE. Tell me if my idea is wrong or unfeasible.
Doing it this way means I can use a powerful pump without worrying about noise and vibration, larger diameter tubes, and a much larger radiator.
Tell me if any of my thinking is wrong here, and if anyone has pictures of something similar that they can show me as examples, that would be awesome. I scoured the watercooling pic thread, but most everyone has their radiators/pumps localized.
Thanks in advance for any help/suggestions!
