So, I've basically got two choices. Force my tubing to bend to the point of pinching down, OR put in a 90' elbow fitting. Now, I can minimize the flow restriction of the 90' elbow fitting by using an oversized fitting(1/2" barb, but the inside of the elbow I plan to use is much larger than that). I would *think* the 90' elbow would be the better choice, but I'm not totally sure on that, so before I go modifying my resevoir and redoing my watercooling loop, I'd like some input
