Jun 2, 2004 #1 D DaMaDo Gawd Joined May 31, 2001 Messages 681 I'm planning on getting a 939 Athlon and either a 9800xt or a 6800u. I was wondering if the current A64 waterblock would fit the new 939s (same holddown?) and if the current GPU coolers would work on either of the two cards mentioned. Thanks.
Jun 2, 2004 #2 H HeThatKnows Gawd Joined Apr 19, 2004 Messages 577 Mounting holes and retention mechanisms are the same across the whole AMD 64 bit line. Current cooler will fit s939 perfectly. Don't know about the graphic cards, they have a habit of change mounting between generations, and some vendor like to make their own changes.
Jun 4, 2004 #3 D DaMaDo Gawd Joined May 31, 2001 Messages 681 Thanks, anyone have a X9800 or 6800 that can vouch for current coolers?
