Water Blocks for AMD Threadripper Sockets TR4 & sTRX4
Discussion in 'For Sale / Trade' started by FrgMstr, Nov 8, 2019.
  1. FrgMstr
    FrgMstr Just Plain Mean Staff Member
    48,452
    May 18, 1997
    I will be listing more Threadripper blocks over the next couple of days. All of these blocks were used for review, so I am breaking these down and making sure these are clean and in great shape before listing. AMD's Robert Hallock did verify that socket TR4 and socket sTRX4 utilize the same exact footprint.
    All Prices are OBO. No Reasonable Offers Declined! Will move these to eBay if these do not sell here.
    Video Roundup of all the coolers here:
    ________________________________________________________________________________________________
    Barrowch AMD RYZEN THREADRIPPER x399/TRX40 CPU Water Block - MFG Page
    Model:FBLTFHAT-04N
    This block did have an LED light strip in it that did not function. I removed it, but included it in the packaging so you can see the dimensions on it if you want to replace. The internal temperature monitor does function. It shows fluid temperature between the fins and the outlet port. The color of the shroud is very much a matte silver. Some of the pictures are a bit off because of camera and lighting.
    $70 Shipped Cont USA - PP F&F
    IMG_20191108_135512.jpg IMG_20191108_135503.jpg IMG_20191108_135558.jpg IMG_20191108_135607.jpg IMG_20191108_135619.jpg IMG_20191108_134104.jpg IMG_20191108_134128.jpg IMG_20191108_134159.jpg IMG_20191108_134229.jpg IMG_20191108_134822.jpg IMG_20191108_135701.jpg IMG_20191108_135822.jpg
    SWIFTECH APOGEE SKF HEIRLOOM SERIES - MFG Page
    Model: Black Chrome with Black Inserts
    This block has an LED power connector on it, but I have never plugged it in. This was a limited one-time order product from Swiftech. The cold plate is not much to look at, but it is nice at flat. It could probably do with a lapping though if you were concerned about that, but I doubt it would get you any temp difference. "The Apogee SKF features an entirely new cooling engine made of 125 micron (< 5 thousandth?s of an inch!) thick slotted fins."
    $90 Shipped Cont USA - PP F&F
    00100dPORTRAIT_00100_BURST20191108144221391_COVER.jpg 00100dPORTRAIT_00100_BURST20191108143753781_COVER.jpg 00100dPORTRAIT_00100_BURST20191108143944125_COVER.jpg 00100dPORTRAIT_00100_BURST20191108144244084_COVER.jpg 00100dPORTRAIT_00100_BURST20191108144344789_COVER.jpg 00100dPORTRAIT_00100_BURST20191108144410012_COVER.jpg IMG_20191108_142725.jpg IMG_20191108_142729.jpg IMG_20191108_142800.jpg IMG_20191108_142830.jpg IMG_20191108_142841.jpg IMG_20191108_142956.jpg IMG_20191108_143824.jpg IMG_20191108_143833.jpg IMG_20191108_145944.jpg
    Koolance CPU-400A-S Water Block - MFG Page
    Model: CPU-400A-S
    Koolance's CPU-400A-S features record-breaking thermal performance with a microfin nickel-plated copper cold plate, acetal top, and rugged steel mounting bracket. Standard G 1/4 BSPP threading will accept any Koolance fitting diameter up to 19mm (3/4in) OD compression style. Please select the desired fitting type for this base model (it does not include fittings).
    IMG_20191108_152906.jpg IMG_20191108_152801.jpg IMG_20191108_152823.jpg IMG_20191108_153451.jpg IMG_20191108_153510.jpg IMG_20191108_152958.jpg IMG_20191108_153324.jpg IMG_20191108_153751.jpg IMG_20191108_152708.jpg IMG_20191108_153942.jpg
    EK Supremacy EVO Threadripper POS Waterblock - MFG Apology
    Model: POS
    $40 Shipped Cont USA - PP F&F
    DTN107 likes this.
  2. FrgMstr
    48,452
    May 18, 1997
  3. workshop35
    workshop35 Gawd
    578
    Nov 24, 2013
    POS model lol
    Deserves a bump
    Creepin_D and FrgMstr like this.
  4. cybrnook
    cybrnook [H]ard|Gawd
    1,528
    Jan 14, 2013
    Giggling 2, and bump 4 U pos
    FrgMstr likes this.
  5. ~ever~
    ~ever~ 2[H]4U
    2,088
    Aug 6, 2000
    I want the Heatkiller :)
  6. FrgMstr
    48,452
    May 18, 1997
  7. vxspiritxv
    vxspiritxv [H]ard|Gawd
    1,480
    Feb 10, 2001
  8. FrgMstr
    48,452
    May 18, 1997
    FWIW, that cooler should do fine on a 1950X. And it will support a 2990WX, IF you turn the flow of the block 90 degrees from stock. It only failed in stock configuration.
    SamirD likes this.
  9. FrgMstr
    48,452
    May 18, 1997
  10. DPOSCORP
    DPOSCORP [H]ardForum Junkie
    9,622
    Mar 10, 2000
    Coulda used a decent pic or video in the OP to help them sell, whatever. free bump
  11. FrgMstr
    48,452
    May 18, 1997
  12. FrgMstr
    48,452
    May 18, 1997
