Guy's,
Looking for a simple way to do some light / med OC on the 3930k / ASUS Rampage IV Extreme combo.
I would like to pick some thing up at the St. Lewis park / MN Microcenter. As I am returning some gear this weekend, and since it is winter, not sure about shipping a aio water cooler when it will freeze.
My case as it was , with my old board and cpu.
Full case info and link http://www.fractal-design.com/?view=product&category=2&prod=112
When I asked support (fractal) they didn't give me that much info..
Me >
Can you provide a list of Closed loop all in one CPU water coolers that are verified to fit on the top?
Looking for something like:
Thermaltake CLW0217 Water 2.0 Extreme/All-In-One Liquid Cooling System
NZXT Kraken X60 RL-KRX60-01 280mm Ultra Performance Liquid CPU Cooler
CORSAIR Hydro Series H110 Water Cooler
Support >
Were not able to provide a list of compatible coolers as its too highly dependent upon the build. The hole spacing between both the 140mm and 120mm fans on the top of the cases is 15mm.
They have the Water 2.0 Extreme in stock, is this a solid choice?
Thanks as always !
Me >
Support >
Thanks as always !
