NoxTek
The Geek Redneck
- May 27, 2002
I thought this was a mighty warm deal to pass along:
https://www.metropcs.com/shop/phones/details/ZTE-ZMAX-PRO/610214647405
ZTE Zmax Pro $159.99 ($99.99 with activation and rebate) from MetroPCS
We bought this for my cousin and I just finished setting it up tonight and I am super impressed.
I normally could care less for ZTE phones, I always considered them a disposable brand with low quality disposable phones - but this guy has gone a long way to changing my mind. It seems to be built fairly well with a front that's nearly all screen yet still has dedicated capacitive buttons which gives you more of that nice 6" screen to look at. The build of Android Marshmallow is super lean and vanilla, with only a few MetroPCS-centric apps installed in the app drawer. The fingerprint sensor on the back works really well - surprising for such an inexpensive phone.
Honestly about my only complaint is that the built-in speaker could be a little louder.
This IS carrier locked to MetroPCS, unlocking details in the following post.
- Octa-core Snapdragon 617 at 1.5ghz with Adreno 405 graphics
- 6" Full HD (1080x1920) IPS screen w/ Gorilla Glass 3
- 2GB RAM
- 32GB flash storage with a microSD slot for up to 256GB additional storage
- 4G LTE bands 2,4,12 (worth noting that AT&T's LTE uses band 2,4,5, and 17 which is a subset of band 12 so in some band 5 and 17 areas your AT&T service could drop to HSPA+, not a big deal)
- Fingerprint reader
- USB Type-C (only 2.0 though)
- QUICK CHARGE 3.0 SUPPORT! Yes, although it's not documented and the unit only comes with a standard charger, this phone actually supports Qualcomm Quick Charge 3.0 . So if you buy or already own a QC compatible charger the phone will take full advantage of it. This means from a dead battery you can get a 60+% charge in 30 minutes time when plugged into a QC3 compatible charger or power bank. SUH-WEET.
