StoleMyOwnCar
- Sep 30, 2013
I've used these in two friends' builds so far, both of them worked fine, so I thought to post this here. It seems to be an okay deal on a fully modular PSU:
http://www.microcenter.com/search/search_results.aspx?Ntt=corsair+rm+refurb
I know these did not initially pass HardOCP's testing, but later on the review goes to note that Corsair made some changes that would have enabled it to earn a pass. This late in the series, I think those changes have likely been made, and any issues likely ironed out. The nice thing about Microcenter is that you can tack on the 2 year replacement plan for really cheap. Like 7$ on the 650W unit. So replacing it is pretty darn easy if things go south.
Newegg also has the 650W option at 60$ after rebate (this rebate seems to extend down the entire RM series):
http://www.newegg.com/Product/Produ...-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Honestly I wouldn't have chosen these if it we did not have to build the PC's almost entirely on the spot within Microcenter (practically no online stores), but out of MC's in-store PSU options I thought it was likely the best deal on a budget.
