Warm? $299 Motile laptop (Walmart) 14" Ryzen 5, 8gb, 256 SSD, upgradable ram w/NVME
Tengis
https://www.walmart.com/ip/Vega-HDM...ial-256GB-8-Performance-Audio-HD-Ca/979627450
  • AMD Ryzen 5 Processor
  • 14″ 1920×1080 Display
  • 8GB Memory
  • 256GB Solid State Drive
  • Radeon Vega 8 Graphics
  • Windows 10
  • Ports
    • 2x USB 3.0
    • 1x USB 2.0
    • 1x HDMI
    • 1x USB Type-C
    • 1x Audio Combo Jack
  • Weight: 2.55 lbs
Apparently they are built fairly decent (especially for the price) and get great battery life. I found a few reviews online stating they bought it to see how bad it was and it ended up being better then a few laptops twice the price. Ram is NOT soldered (upgradable) and it has a spare NVME slot. It has single channel ram so dont expect to push the graphics super hard.
Bought one for the wife to replace her aging Dell Venue 11 Pro from like 2013/2014. I figured this thing would be way faster and she is content with her Dell and says it "works just fine" lol.
Reddit posts here with some info:
https://www.reddit.com/r/buildapcsales/comments/e8ze9h https://www.reddit.com/r/Amd/comments/dp52am
tungt88
Yeah, it's a super good deal for what you're getting -- I recommended a better (but still quite cheap) version to a good friend of mine, and he bought the Motile.
illram
Lol I bought this yesterday for $349, which I thought was a crazy deal. Jesus.
Tsumi
I don't think anything is going to beat the Costco HP deal, but this is still decent if you're not looking for gaming performance. Would be significantly better if it had dual channel memory.
Spun Ducky
Another good deal that is in the same boat is this Dell.
https://www.walmart.com/ip/Dell-Ins...ickid=W8TV5w3UhxyJRbv0EHQlB1XYUknyp2zvzRBs0A0
While the screen isn't FHD, it is fairly easy to upgrade, it is also mismarked as i3 while in the box you actually get a quad core i5 1035g4 or i5 1035g7 with iris graphics. I got one and upgraded it to 32gb ram, 1080 ips screen, and 1tb nvme. Quite a time to be looking for a cheap laptop. I am just blown away by the sub $500 range right now.
Tengis
I specifically didnt buy that one because the screen was junk. How much did it set you back to upgrade it?
Spun Ducky
I am not sure on the total cost as I had all the parts on hand. Whenever there is a killer deal i order sets of things like ram for future builds. If I had to guess probably another 250 dollars or so. The biggest thing is i got to choose a very high end IPS screen vs the mediocre one most machines come with.
elite.mafia
Broke Back [H]
That thing looks fucking awful.... 4gb of ram and a 720p screen with an i3... pass... even if it is an i5 (i doubt it is, they probably are repeatedly fucking up the shipments or something) still shit screen and ram. Much better deals out there
Reactions: Nokia
Tsumi
It's Intel's fault, they can't supply enough i3 G1 chips so they've been supplying i5 G4 chips instead. Picked up an HP that was supposed to be i3 G1 from Costco, and it came with an i5 G4 and a 1080p IPS screen for $280. Dual channel upgradeable RAM and supports PCI-E NVME drives. There's a giant thread on the HP laptop on SD, though it ended right before Thanksgiving. Nearly everyone that got the HP got the i5 G4.
What I am curious to know is how Spun Ducky upgraded the Dell to 1080p IPS and at what cost.
Spun Ducky
$40 for this screen off ebay: LP140WF3-SPD1
Then I just followed the service manual for disassembly. It uses a standard 30 pin edp cable and mounting points,connector location, and size all match up perfectly with the stock screen.
Eshelmen
I'm worried about battery life. Reviews say decent. Can we get a confirmation of average life span before needing a charge?
I know the laptop is heavily discounted, but I've never been satisfied with battery life on a $300 laptop. I'll bite if there's some average figures.
The Lurker
This beats it by a lot. 256gb SSD vs 64gb, 4 vs 8 gb ram and a Pentium Silver Vs Ryzen 3? come on.
Tsumi
The Costco deal before Thanksgiving was an i5 G4. 256gb SSD was too small, as is 8gb of RAM, so they would have been upgraded regardless. The i5 G4 smacks Ryzen 3.
The Lurker
OOOOOH. I thought the one they had up now.
pillagenburn
Ill wait for used 150$ HP or Dell
Ryzen laptops on ebay. Still running a 175$ elitebook 745 g3
