I'm sick and tired of being bottlenecked by my Athlon x2 5200+. Even at 2.8ghz I'm still way too cpu limited with my 8800 Ultra in everything and it's showing tell tale signs. Running newer games with max details yields poorer performance than what my video card is capable of in other setups with C2D/C2Q. Dropping the resolution yields very little performance increase in most cases.
I've tweaked with this system enough to know that it's not a driver related problem. My 3dmark 2006 score (low 10k range) is consistent with others with similar specs.
So basically I want to grab a new motherboard/cpu to put in this system, while leaving everything else unchanged.
Here's what I have now:
Mobo: MSI K9A Platinum
Cpu: Athlon x2 5200+ @ 2.8ghz
Ram: 4gb (2 x 2gb) Kingston HyperX DDR2 800 (4-4-4-12)
Gfx: 8800 Ultra
PSU: Thermaltake Toughpower 700w
So for just short of $500, I came up with this:
Asus Rampage Formula
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131284
C2Q Q6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
From what I've read, this motherboard should work with my existing DDR2 800 memory, and everything else shouldn't be a problem. I should be able to just swap out the cpu/mobo and install a fresh copy of windows, shouldn't I?
I'm pretty set on getting the Q6600 since it's been selling like hotcakes and is quite cheap now, so the only question that remains concerns the motherboard.
Is this a good choice of a motherboard? Any other recommendations?
Also, I know Nehalem is on its way, but I'd rather stick with the C2Q while its still in its prime.
Basically, the plan is to let my 8800 Ultra stretch its legs for now, and then get a 4870x2 or equivalent later on to let this system really scream.
Gfx: 8800 Ultra
C2Q Q6600
