Want to build a dual WAN Linux router
I've been looking for some guides for how to set up a dual WAN router and I'm having a tough time finding some how-to's. I've tried pfSense and find it kind of difficult to configure. I have it installed but am stuck getting the WAN ports configured.
Is there a way to do this in a Linux setup that anyone knows of?
iamwhoiamtoday
Zentyal, IPFire, and ClearOS are all pretty easy / straightforward to setup, at least, in my experience. Never had the dual WAN thing going on though, just the simple / straight forward single 'net connection.
robvas
PfSense is the easy way to do it. What were you having problems with? Make sure your ping probes are on different gateways or the failover won't work.
TCM2
OpenBSD has virtual routing tables (rdomains). Traffic is assigned using pf. You could force some clients over one link, round-robin between links or hack together some failover.
I'm running 6 VPNs where one of them is tunneled through another one. It's a breeze not worrying about 6+ different default routes or overlapping VPN client addresses.
There's no fancy HTTP interface though, only clean BSD design.
